I can’t make friends with Stalwart and Bind9 in any way, can anyone tell me what the mistake might be?
A brief description of the actions is provided below.
I use TCP port 953 for synchronization.
root@ns0:/var/lib/bind# named -v
BIND 9.20.24-1ubuntu0.3-Ubuntu (Stable Release) id:
/etc/bind/named.conf
key “stalwart” {
algorithm hmac-sha256;
secret “ckzcjcAHqTZAWg2GsrIZnzdJAMWdAPauLxW5lY3SjSc=”;
};controls {
inet 192.168.0.236 port 953
allow {
192.168.0.229;
} keys {
“stalwart”;
root@ns0:/var/lib/bind# named-checkconf
root@ns0:/var/lib/bind# systemctl restart named
root@ns0:/var/lib/bind# date -u
eq (+/- 1 second)
root@stalwart:/var/lib/bind# date -u
Go to: http://stalwart:8080/admin/Management/x:Domain
Switch DNS from Automatic to Manual, and back to Automatic.
/var/log/syslog | grep named
2026-10-12T11:15:13.301445+00:00 ns0 named[5516]: invalid command from 192.168.0.229#60366: out of range
2026-10-12T11:15:13.302183+00:00 ns0 named[5516]: invalid command from 192.168.0.229#60380: out of range
2026-10-12T11:15:13.303343+00:00 ns0 named[5516]: invalid command from 192.168.0.229#60388: out of range
2026-10-12T11:15:13.304430+00:00 ns0 named[5516]: invalid command from 192.168.0.229#60404: out of range
2026-10-12T11:15:13.305517+00:00 ns0 named[5516]: invalid command from 192.168.0.229#60420: out of range
2026-10-12T11:15:13.306526+00:00 ns0 named[5516]: invalid command from 192.168.0.229#60430: out of range
2026-10-12T11:15:13.307481+00:00 ns0 named[5516]: invalid command from 192.168.0.229#60434: out of range
2026-10-12T11:15:13.308412+00:00 ns0 named[5516]: invalid command from 192.168.0.229#60440: out of range
2026-10-12T11:15:13.309327+00:00 ns0 named[5516]: invalid command from 192.168.0.229#60446: out of range
2026-10-12T11:15:13.310135+00:00 ns0 named[5516]: invalid command from 192.168.0.229#60462: out of range
2026-10-12T11:15:13.311021+00:00 ns0 named[5516]: invalid command from 192.168.0.229#60464: out of range
2026-10-12T11:15:13.311843+00:00 ns0 named[5516]: invalid command from 192.168.0.229#60476: out of range
2026-10-12T11:15:13.312765+00:00 ns0 named[5516]: invalid command from 192.168.0.229#60492: out of range
2026-10-12T11:15:13.313649+00:00 ns0 named[5516]: invalid command from 192.168.0.229#60506: out of range
2026-10-12T11:15:13.314450+00:00 ns0 named[5516]: invalid command from 192.168.0.229#60518: out of range
2026-10-12T11:15:13.315432+00:00 ns0 named[5516]: invalid command from 192.168.0.229#60520: out of range
2026-10-12T11:15:13.316367+00:00 ns0 named[5516]: invalid command from 192.168.0.229#60532: out of range
2026-10-12T11:15:13.317140+00:00 ns0 named[5516]: invalid command from 192.168.0.229#60548: out of range
2026-10-12T11:15:13.317976+00:00 ns0 named[5516]: invalid command from 192.168.0.229#60556: out of range
2026-10-12T11:15:13.318564+00:00 ns0 named[5516]: invalid command from 192.168.0.229#60564: out of range
2026-10-12T11:15:13.319444+00:00 ns0 named[5516]: invalid command from 192.168.0.229#60570: out of range
