Bootstrap remotely from inside lxc container
I’m trying to set up a stalwart server inside of an lxc container, but can’t figure out how to bootstrap it remotely. My server install is headless so I would normally use nginx reverse proxy to expose my services, but before bootstrapping I can’t figure out how to change my trusted proxy settings to include the host device. Thank you very much for your time
The setup wizard is meant to be done directly against the container’s HTTP listener, not through the reverse proxy; the proxy and trusted-network config come afterward. From the LXC host or any machine on the same bridge, point a browser at the container’s IP on port 8080: http://:8080/admin. If the host is headless, tunnel it over SSH, e.g. ssh -L 8080::8080 and then open http://localhost:8080/admin.
Once you’ve completed the wizard and the server restarts, set proxyTrustedNetworks (System Settings, Network) to your proxy/host address and put nginx back in front. Docs: Overview | Stalwart (the “Initial setup behind a proxy” section).
