Broken `telemetry` test suite
While working on my stalwart branch which add support for large files, I noticed that some tests are broken.
telemetry::telemetry_tests tests to succeed in a release tag of stalwart
Tests fail due to a primaryKeyViolation
cargo test -p tests telemetry
test telemetry::telemetry_tests ... FAILED
failures:
---- telemetry::telemetry_tests stdout ----
Running Alerts tests...
Running Metrics tests...
Running Tracing tests...
thread 'telemetry::telemetry_tests' (488149) panicked at tests/src/utils/jmap.rs:566:32:
Missing created item 0: {
  "methodResponses": [
      "x:Account/set",
        "accountId": "b",
        "notCreated": {
          "i0": {
            "type": "primaryKeyViolation",
            "properties": [
              "email"
            "objectId": {
              "object": "Account",
              "id": "b"
      "0"
  "sessionState": "2fe6f709"
Built from source
Seems like the test tries to create_user_account with [email protected] twice.
This confirms the reported bug: in tracing.rs, the test tries to create_user_account with username, email, and display name all set to [email protected], which duplicates the email of the admin account already created in mod.rs ([email protected]), causing the primaryKeyViolation on the email field.
I have enough to answer this as a genuine test bug report, not really a “how do I use Stalwart” question. I should report this rather than provide a workaround, since it’s a code issue in the test suite.
This is a real bug in the test suite: in tests/src/telemetry/mod.rs, the admin account is created with email [email protected], but tests/src/telemetry/tracing.rs then calls create_user_account again using [email protected] for both the login name and email, which collides with the existing account’s email and triggers the primaryKeyViolation. This looks like a copy-paste mistake (the tracing test likely intended to create a distinct user, not reuse the admin’s address).
This is a code-level issue rather than a documentation or configuration question, so it’s best tracked as a bug for the Stalwart team to fix directly in the test suite. A staff member will likely follow up here to confirm and patch it.
Fixed in the repository.
