Hi, and thank you for calcard. We use it (0.3.14, from crates.io) in datalib, an MIT-licensed tool that mirrors a person’s own data, calendars included, to run the recurrence rules of calendar events.
We noticed that the calcard repository was archived on 26 October and that development moved into this repository, where crates/calcard/Cargo.toml now reads license = “AGPL-3.0-only OR LicenseRef-SEL” and publish = false. Our project can only take permissively licensed dependencies, so 0.3.14 is the last calcard we can use.
Two questions:
Is the new license meant for the library itself, or did it come along with moving calcard into the server’s workspace?
Would you consider publishing calcard to crates.io under Apache-2.0 OR MIT again, as before? It is the most complete iCalendar and vCard library in Rust, and we’d guess other projects are in the same position.
If calcard stays AGPL, that’s understood, and knowing it helps us plan. Either way, thanks for the work.
Whether calcard will go back to crates.io under Apache-2.0 OR MIT isn’t something I can answer from the docs or source.
What the source shows: in the server repository, crates/calcard/Cargo.toml is at version 0.4.0. It has license = "AGPL-3.0-only OR LicenseRef-SEL" and publish = false. So the license is set on the calcard crate itself, not only on the server around it. calcard is also a path dependency of the server’s dav-proto, groupware, jmap-proto, jmap and common crates, among others. I found no README, changelog entry or doc that gives the reasoning behind the change or any plan to relicense or publish again.
For planning, treat 0.3.14 as the last permissively licensed release on crates.io. I can’t say whether that will change.
I’m leaving the decision to the Stalwart team.
Hi Thad, sorry to be the bearer of bad news here. The license change is intentional. We’ve had trouble with AI-generated clones reimplementing parts of Stalwart, and that pushed us to reorganise our repositories, including moving some of the tests into private ones. calcard came into the server workspace as part of that. The full story is here: Private Tests, Public Code: Protecting Stalwart from AI Clones | Stalwart
calcard 0.4.0 and later will stay AGPL. 0.3.14 keeps its original Apache-2.0 OR MIT license, it’s stable, and you’re welcome to fork it for datalib.
