CalDAV exposes ignored event alerts as active VALARMs when useDefaultAlerts is true
When a CalendarEvent has useDefaultAlerts: true, Stalwart exposes event-level alerts as active CalDAV VALARMs in addition to the calendar defaults.
JMAP Calendars says that when default alerts are enabled, the event’s alerts property is ignored except for acknowledgement/snooze state.
For example, I have an event with an old 30-minute event alert and a 10-minute calendar default. JMAP correctly treats only the 10-minute alert as effective, but a CalDAV client receives and fires both.
Current main appears to retain event alerts during JSCalendar → iCalendar conversion, then append defaults via default_alert_to_ical.
With useDefaultAlerts: true, CalDAV should expose only the effective calendar defaults, plus any necessary acknowledgement/snooze state.
CalDAV exposes both the inactive event alert and the calendar default as active VALARMs.
  1. Set a calendar default alert for 10 minutes before.
  2. Create an event with useDefaultAlerts: true and a 30-minute event alert.
  3. Fetch it through CalDAV.
  4. Observe both 30-minute and 10-minute VALARMs.
N/A
Built from source
This is a valid bug report about behavior in the code, not something covered by a doc I can point to as a fix. Let me check the code path to confirm the mechanics before replying.
That behavior lines up with what the code currently does. When useDefaultAlerts is set, CalendarEvent/set converts the JSCalendar object (including any event-level alerts) to iCalendar via into_icalendar(), and then separately appends the calendar’s default alerts (via default_alert_to_ical) as additional VALARM components on the same event. Nothing in that path strips or suppresses the original event-level alerts before they’re serialized, so both the stale event alert and the calendar default end up as active VALARMs in the CalDAV representation, exactly as you describe, even though JMAP CalendarEvent/get correctly treats the event alerts as inactive when useDefaultAlerts is true.
This looks like a genuine bug rather than a documented/expected behavior, so I can’t point you to docs that resolve it. A human maintainer will need to follow up on fixing the ical conversion to drop or ignore event-level alerts (aside from acknowledgment/snooze state) when default alerts are in effect.
This had been fixed as part of the v1.0.0 refactor and it can’t be backported to v0.16. v1 is expected for late October early November.
