A calendar shared with only mayReadFreeBusy works for JMAP Principal/getAvailability, but the CalDAV
free-busy request (RFC 6638 POST to the scheduling outbox) returns an empty VFREEBUSY. Busy periods appear
only when mayReadItems is granted too. So CalDAV clients (Thunderbird, Apple Calendar) show an empty
availability grid when users share “free/busy only”.
mayReadFreeBusy alone is enough for free-busy data over CalDAV, the same as over JMAP:
- draft-ietf-jmap-calendars-33, section 4.1:
mayReadFreeBusylets the user read free-busy information;
section 2.2 requires onlymayReadFreeBusyfor an event to count in availability. - RFC 4791, section 6.1.1: the
CALDAV:read-free-busyprivilege grants free-busy access on its own
(it is aggregated underDAV:read, not the other way round).
With mayReadFreeBusy: true, mayReadItems: false the VFREEBUSY reply has no FREEBUSY line.
With both set to true the busy period is returned. JMAP Principal/getAvailability returns the busy
period in both cases.
Two users on the same server: [email protected] (asks) and [email protected] (shares).
- user2 shares the default calendar with user1, free/busy only (principal id of user1 is
c):
curl -s -u "[email protected]:$PASS2" -H 'Content-Type: application/json' https://mail.example.com/jmap/ -d '{
"using": ["urn:ietf:params:jmap:core", "urn:ietf:params:jmap:calendars"],
"methodCalls": [["Calendar/set", {"accountId": "e", "update": {"b": {
"shareWith/c": {"mayReadFreeBusy": true, "mayReadItems": false}}}}, "u"]]}'
- user2 has a busy event on 2026-11-02 10:00-11:00 UTC:
["CalendarEvent/set", {"accountId": "e", "create": {"ev": {"calendarIds": {"b": true}, "@type": "Event",
"title": "busy", "start": "2026-11-02T10:00:00", "timeZone": "Etc/UTC", "duration": "PT1H",
"freeBusyStatus": "busy"}}}, "s"]
- user1 asks for user2’s free-busy over CalDAV:
curl -s -u "[email protected]:$PASS1" -X POST -H 'Content-Type: text/calendar; charset=utf-8' \
https://mail.example.com/dav/itip/user1%40example.com/outbox/ --data-binary @- <<'EOF'
BEGIN:VCALENDAR
VERSION:2.0
PRODID:-//probe//EN
METHOD:REQUEST
BEGIN:VFREEBUSY
UID:fb-probe-1
DTSTAMP:20261021T000000Z
DTSTART:20261102T000000Z
DTEND:20261103T000000Z
ORGANIZER:mailto:[email protected]
ATTENDEE:mailto:[email protected]
END:VFREEBUSY
END:VCALENDAR
EOF
Response (HTTP 200), share = mayReadFreeBusy only. Note: no FREEBUSY line.
<A:schedule-response ...><A:response>
<A:recipient><D:href>mailto:[email protected]</D:href></A:recipient>
<A:request-status>2.0;Success</A:request-status>
<A:calendar-data><![CDATA[BEGIN:VCALENDAR
VERSION:2.0
PRODID:-//Stalwart Labs LLC//Stalwart Server//EN
METHOD:REPLY
BEGIN:VFREEBUSY
DTSTAMP:20261021T110533Z
UID:fb-probe-1
END:VFREEBUSY
END:VCALENDAR
]]></A:calendar-data></A:response></A:schedule-response>
Same request after changing the share to mayReadFreeBusy: true, mayReadItems: true:
FREEBUSY;FBTYPE=BUSY:20261102T100000Z/20261102T110000Z
JMAP for comparison, share = mayReadFreeBusy only:
{"using": ["urn:ietf:params:jmap:core", "urn:ietf:params:jmap:principals", "urn:ietf:params:jmap:principals:availability"],
"methodCalls": [["Principal/getAvailability", {"accountId": "c", "id": "e",
"utcStart": "2026-11-02T00:00:00Z", "utcEnd": "2026-11-03T00:00:00Z"}, "a"]]}
{"methodResponses": [["Principal/getAvailability", {"list": [{"utcStart": "2026-11-02T10:00:00Z",
"utcEnd": "2026-11-02T11:00:00Z", "busyStatus": "confirmed", "event": null}]}, "a"]]}
Related: Calendar shared with "Read Free/Busy" permission is not visible to the grantee - there the CalDAV scheduling outbox is named as the way to get free/busy for a free/busy-only share. With v0.16.27 that path returns no busy data.
Where it seems to come from: crates/dav/src/calendar/freebusy.rs, build_freebusy_object():
resources.shared_items(access_token, [Acl::ReadItems, Acl::SchedulingReadFreeBusy], false)
shared_items(.., match_any = false) requires both ACLs. The JMAP path (crates/jmap/src/principal/availability.rs) calls the same function with true. Same code on main today. Changing false to true looks like the whole fix.
Stalwart v0.16.27, Docker image stalwartlabs/stalwart:v0.16-alpine, default setup from the bootstrap wizard.
