CalendarEvent/set does not persist useDefaultAlerts: false.
An event created or updated with useDefaultAlerts: false is subsequently returned by CalendarEvent/get with useDefaultAlerts: true.
This is also reproducible against current Stalwart main.
Per the JMAP Calendars specification, useDefaultAlerts is an optional Boolean with a default value of false.
When an event is created or updated with:
"useDefaultAlerts": false
a subsequent CalendarEvent/get should return false, and the event should not use the calendar’s default alerts.
Stalwart accepts the CalendarEvent/set request and reports the object as successfully created/updated, but a subsequent CalendarEvent/get returns:
"useDefaultAlerts": true
The same behavior occurs both when:
- creating a new event with
useDefaultAlerts: false - changing an existing event from
truetofalse
Current source appears to treat a missing per-user event preference as true in CalendarEvent/get, while CalendarEvent/set does not persist the false state.
- Create a calendar event using
CalendarEvent/setwith:
"uid": "default-alert-test",
"calendarIds": {
"<calendar-id>": true
"title": "Default alert test",
"start": "2026-09-30T12:00:00",
"duration": "PT30M",
"timeZone": "Pacific/Auckland",
Confirm that
CalendarEvent/setreports the object as successfully created. -
Fetch the event using
CalendarEvent/get, explicitly requestinguseDefaultAlerts. -
Observe that Stalwart returns:
The issue can also be reproduced by creating an event with useDefaultAlerts: true and then updating it with:
The update succeeds, but CalendarEvent/get still returns true.
No error is reported. CalendarEvent/set returns a successful created or updated response and advances the collection state.
Built from source
