According to Exporting server state | Stalwart the --include-secrets flag is only client-side, and in order to actually view the secret field, the server must allow it, which is does not by default. Fair enough, secure by design.
However I cannot find any documented permission on the server side, which allows a given user or role to view secret fields.
Just trying to extract the generated DKIM keys, so that they can be backed up, but the question applies equally to any field marked as secret.
The storage can of course be queried directly (RocksDB, Postgres, FoundationDB etc.), but has anybody succeeded in configuring the server to allow viewing the secret contents, using stalwart-cli? It would be useful to be able to script this process and not need to access backend storage directly.
To demonstrate: stalwart-cli -k snapshot DkimSignature --include-secrets --allow-unresolved Tenant,Domain (See the dkimsignature.xxxxx: {privateKey: {secret}} value).
There isn’t a setting to unmask secrets on the server today. Stalwart substitutes **** for every secret field before any role/permission check, including DKIM private keys, API key secrets and OAuth client secrets. The --include-secrets flag on the CLI only controls whether the received **** token is preserved in the exported plan; it doesn’t ask the server for the cleartext.
Given that web frontend also goes via JMap that means that outside of querying the database directly there is no way in 0.16 to migrate secrets between instances. That is unpleasant for considering future migration between instances, if that would be needed: v0.15 to v0.16 exported all relevant secrets for that migration.
For secrets already stored inline, nothing in the API will hand them back, so moving to a new instance means re-issuing them or reading them out of the backing store directly. Masking is unconditional in the serializer, not permission-gated, so no role or setting changes it.
What makes them portable is not storing them inline in the first place. SecretText fields accept a File or EnvironmentVariable variant, for example {"@type": "File", "filePath": "/etc/stalwart/dkim/example.com.key"}. Those carry only a path or a variable name, so snapshot --include-secrets exports them verbatim and apply restores them on the new instance, with the key material travelling with the files or the environment and never entering the database. DkimSignature | Stalwart lists the variants.
Also, our snapshot docs are wrong and sent you looking for something that does not exist: two lines on that page say masking can be disabled server-side for administrative exports. No such setting exists. I’ll get the page corrected to describe the File and environment-variable approach instead.
