Hello, for one of our client we have activated the licence on the wrong domain. how can we change it ?
At this point we are not able to activate stalwart
FoundationDB
This confirms that licenses are tied to a specific domain and the docs don’t describe a self-service way to change that domain binding (it is set by the licensing portal when the license is issued, not configurable in Stalwart itself).
Based on this, I’ll answer accordingly: the domain is baked into the signed license string itself, issued via the Stalwart Labs Licensing Portal, so changing it requires a reissue from the portal/licensing team, not a server-side config change.
A license key is cryptographically bound to the domain it was issued for, that binding is set when the license is generated on the Licensing Portal, not something you can edit inside Stalwart itself. Entering a new licenseKey value on the Enterprise object only lets you load a different license string, it won’t retroactively change the domain of the one you already have.
To get a license re-issued for the correct domain, you’ll need to go through the Stalwart Labs Licensing Portal (https://license.stalw.art) where your subscription was purchased, since that’s the only place that can mint a new signed license tied to the right domain. I don’t have visibility into billing/licensing support channels from the docs, so a human/staff member will need to confirm the exact process for correcting an already-issued license.
Reference: Enterprise License | Stalwart
Seen on forum: contact [email protected]
