Consent screen splits words mid-word: "after you si / gn in."
On the 1.0 “Authorize access” screen, the line under the scope list breaks in the middle of ordinary words. With a redirect host of staff.example.com it renders as:
You will be sent back to staff.example.com after you si
gn in.
Cause: in resources/html-templates/login.html, .redirect-note sets word-break: break-all (lines 368 to 373 at v1.0.0; main is the same today):
break-all lets the browser break between any two letters, so it splits ordinary words, not just long host names.
Suggested fix: use overflow-wrap: anywhere instead. It wraps at spaces first and breaks inside a word only when that word cannot fit on a line, so long host names still wrap. (word-break: break-word, which .client-name already uses, does the same.) .client-host has the same break-all rule; it holds only a host name, so it matters less there.
The line wraps between words: “after you” / “sign in.” Only a host name too long for the line breaks inside itself.
Words break at whichever letter reaches the edge of the card: “si” / “gn in.” With a longer host, other words split too, for example “yo” / “u sign in.”
  1. Register an OAuth client whose redirect URI host is about 17 characters long, for example staff.example.com.
  2. Start an authorization code sign-in for that client and sign in.
  3. On the “Authorize access” screen, read the “You will be sent back to … after you sign in.” line.
Where the break lands depends on the host length and the font. Any host that makes the sentence wrap shows a split inside a word.
v1.x
Seen on a live v1.0.0 server. Reproduced with the CSS from login.html at v1.0.0 in Chrome 156 and in WebKit (Safari’s engine) on macOS 27.2; overflow-wrap: anywhere fixed it in both.
Your diagnosis matches the current source. In resources/html-templates/login.html in the server repo, .client-host (line 299) and .redirect-note (line 372) both set word-break: break-all. .client-name (line 293) uses word-break: break-word. That is why the sentence in .redirect-note can split mid-word, as in “si / gn in”.
Your suggested change is to use overflow-wrap: anywhere on .redirect-note and .client-host. The docs don’t cover this template’s CSS, so I can’t point to a documented fix. It is a template bug that a human will need to confirm and fix. Until a fix lands, you can’t change the built-in template through configuration.
This has been fixed, we expect to release 1.0.1 in the next few hours.
