Custom Logos not working for Domains
Custom per-domain logos don’t show up.
On the Enterprise edition you can give each domain (or tenant) its own logo, so that when your users open the login / account page they see your branding instead of the default Stalwart one.
The problem: setting a logo on a domain has no effect. You add the logo, save it, and the login page still shows the default logo, for every domain. It doesn’t matter whether the logo is set correctly; it’s simply never used.
With a logo set on a domain (or tenant) principal, GET /logo on that domain’s hostname serves that logo, per the documented hierarchy (domain → tenant → enterprise.logo-url → built-in).
The domain/tenant logo is silently ignored; /logo always falls back to enterprise.logo-url or the built-in logo. No error is logged
  1. Enterprise edition, valid
  2. Set logo on a domain principal (e.g. example.org) to any reachable image URL.
  3. GET https://mail.example.org/logo
  4. domain’s logo is never returned
LDAP
Proposed Patch:
Patch 1: URL Images
crates/common/src/enterprise/mod.rs
@@ logo_resource()
         if let Some((d_id, t_id)) = self.domain(domain).await?.map(|d| (d.id, d.id_tenant))
-            && let Some(domain_record) = self.registry().object::<Domain>(domain_id.into()).await?
+            && let Some(domain_record) = self.registry().object::<Domain>(d_id.into()).await?
             logo_url = domain_record.logo;
             domain_id = d_id;
Patch 2: base64-encoded Images
-use mail_parser::DateTime;
+use mail_parser::{DateTime, decoders::base64::base64_decode};
@@ logo_resource()
         let mut logo = None;
+        if let Some((meta, data)) = logo_url
+            .as_deref()
+            .and_then(|url| url.strip_prefix("data:"))
+            .and_then(|uri| uri.split_once(','))
+            let contents = base64_decode(data.as_bytes()).ok_or_else(|| {
+                trc::ResourceEvent::DownloadExternal.into_err().details("Failed to decode logo")
+            if contents.len() > MAX_IMAGE_SIZE {
+                return Err(trc::ResourceEvent::DownloadExternal
+                    .into_err().details("Download exceeded maximum size"));
+            let content_type = meta
+                .split(';').next().filter(|ct| !ct.is_empty()).unwrap_or("image/svg+xml");
+            logo = Resource::new(content_type.to_string(), contents).into();
+            logo_url = None;
         if let Some(logo_url) = logo_url {
Same symptom was reported and closed in #1856, #2572, #2074 without identifying the cause; it’s still broken in v0.16.12
I pulled the current source and can confirm this is a real bug, not a config issue. In logo_resource() (crates/common/src/enterprise/mod.rs), the domain lookup does:
domain_id here is still the initial sentinel u32::MAX set a few lines above (it’s only assigned after this lookup), rather than the just-obtained d_id. So registry().object::<Domain>(...) is always queried with u32::MAX, never finds a match, and domain_record.logo is never read — meaning any per-domain (or tenant, since tenant lookup depends on tenant_id from that same failed branch) logo is silently ignored and the code falls through to enterprise.logo-url or the built-in default. Your Patch 1 (using d_id instead of domain_id) matches the actual cause exactly.
This is a code-level defect, so it needs a fix in a release rather than a config change on your end. A staff member will need to review and merge the correction (your patch looks correct); I can’t push fixes myself, but I’ve flagged the exact location so it’s actionable.
Fixed in v0.16.13 which will be released this week.
Not sure it has been fully fixed yet, even in 0.16.14.
What does seem to be working is the first login screen for the additional domain/tenant (initial username screen as in https://mail.mycorp.com/account/loing). It shows the correct tenant/domain logo for “mycorp”.
However, the second login screen (username/password) and the third login screen (OTP) still show the default enterprise or built-in logos. They do not show the domain or tenant logo, which was visible in the first screen. Note that the urls of login screens 2 and 3 start with the server hostname, e.g. https://mail.myhostname.net/login?response_type=code&client_id=stalwart-webui&redirect_uri=https%3A%2F%2Fmail.mycorp.com[....]
This inconsistent change in URL and logo throughout the login process may raise the suspicion of a phishing attempt.
Great. Thanks for fixing this. :+1:
