When trying to delete a clusternode I get an error message.
$ docker run --rm -e STALWART_URL=:8080 -e STALWART_TOKEN=API_ stalwartlabs/cli query ClusterNode
Id Node ID Hostname Last Renewal Status
a 0 stalwart 2026-07-17T13:04:17Z Active
b 1 stalwart-node-2 2026-07-17T06:36:11Z Stale
c 2 mx1. 2026-07-17T13:18:33Z Active
d 3 “mx1.” 2026-07-17T06:43:21Z Stale
e 4 “mx2.” 2026-07-17T06:44:08Z Stale
f 5 mx2. 2026-07-17T12:48:12Z Active
$ docker run --rm -e STALWART_URL=:8080 -e STALWART_TOKEN=API_ stalwartlabs/cli delete ClusterNode --ids 1,3,4 --debug
[debug] → GET http://:8080/api/schema
[debug] ← GET http://:8080/api/schema status=302 Found content-type=(none) content-length=0 content-encoding=identity
[debug] → GET http://:8080/api/schema/
[debug] ← GET http://:8080/api/schema/ status=200 OK content-type=application/json content-length=148000 content-encoding=gzip
[debug] → GET http://:8080/jmap/session
[debug] ← GET http://:8080/jmap/session status=200 OK content-type=application/json; charset=utf-8 content-length=1739 content-encoding=identity
[debug] → POST http://:8080/jmap
[debug] ← POST http://:8080/jmap status=200 OK content-type=application/json; charset=utf-8 content-length=263 content-encoding=identity
1 failed: error: forbidden
Telemetry objects cannot be deleted
3 failed: error: forbidden
4 failed: no response from server
0 deleted, 3 failed
error: one or more deletions failed
The clusternode should be deleted.
The request is denied with the message “1 failed: error: forbidden
Telemetry objects cannot be deleted”.
$ docker run --rm -e STALWART_URL=:8080 -e STALWART_TOKEN=API_ Package cli · GitHub query ClusterNode
$ docker run --rm -e STALWART_URL=:8080 -e STALWART_TOKEN=API_ Package cli · GitHub delete ClusterNode --ids 1,3,4 --debug
0 deleted, 3 failed
$ docker run --rm -e STALWART_URL=<snip>:8080 -e STALWART_TOKEN=API_<snip> ghcr.io/stalwartlabs/cli delete ClusterNode --ids 1,3,4 --debug
[debug] -> GET http://<snip>:8080/api/schema
[debug] <- GET http://<snip>:8080/api/schema status=302 Found content-type=(none) content-length=0 content-encoding=identity
[debug] -> GET http://<snip>:8080/api/schema/<snip>
[debug] <- GET http://<snip>:8080/api/schema/<snip> status=200 OK content-type=application/json content-length=148000 content-encoding=gzip
[debug] -> GET http://<snip>:8080/jmap/session
[debug] <- GET http://<snip>:8080/jmap/session status=200 OK content-type=application/json; charset=utf-8 content-length=1739 content-encoding=identity
[debug] -> POST http://<snip>:8080/jmap
[debug] <- POST http://<snip>:8080/jmap status=200 OK content-type=application/json; charset=utf-8 content-length=263 content-encoding=identity
0 deleted, 3 failed
