Disabled MTA-STS still advertises DNS records and panics serving mta-sts.txt (Mode::None unreachable!() in Display)
(Assistance from Claude)
With MTA-STS disabled (mtaSts.mode = disable), Stalwart v0.16.13/v0.16.14 still (a) builds an in-memory MTA-STS policy object with Mode::None, (b) advertises mta-sts. / _mta-sts. records for every domain in its DNS zone output, and (c) panics whenever a remote MTA fetches https://mta-sts.<domain>/.well-known/mta-sts.txt:
thread ‘tokio-rt-worker’ panicked at crates/common/src/config/smtp/resolver.rs:365:27:
internal error: entered unreachable code
In production this was a continuous panic storm (Gmail’s policy fetchers retry in bursts of ~4, all day, on both cluster nodes).
No crashes/errors.
Chain (v0.16.13 source)
Policy::try_parse (crates/common/src/config/smtp/resolver.rs:261): when mta_sts.mx_hosts is empty it falls back to SystemSettings.mail_exchangers / default_hostname — effectively never empty — and maps PolicyEnforcement::Disable → Mode::None, returning Some(policy) even though the feature is disabled. So session.mta_sts_policy is Some with mode: None.
The DNS record generator (crates/common/src/network/dns/records.rs:123, DnsRecordType::MtaSts) only checks is Some — it emits mta-sts. CNAME + _mta-sts. TXT “v=STSv1; id=…” for every domain, advertising MTA-STS that the operator disabled.
The HTTP handler (crates/http/src/request.rs:328, (“mta-sts.txt”, GET)) calls policy.to_string(); impl Display for Policy (resolver.rs ~line 360) has:
match self.mode {
Mode::Enforce => f.write_str(“enforce”)?,
Mode::Testing => f.write_str(“testing”)?,
Mode::None => unreachable!(),
→ panic on every fetch. Fetchers get a dropped connection and retry.
Expected
mode = disable should mean: mta_sts_policy = None, no mta-sts./_mta-sts. records emitted, and /.well-known/mta-sts.txt returning 404. Alternatively (RFC 8461 §5 offers mode: none as a real value for graceful shutdown), Display could legitimately serialize mode: none — but then the config needs to distinguish “publish mode:none” from “feature off”, and unreachable!() must go either way.
mtaSts settings: {“mode”:“disable”,“mxHosts”:{}} (defaults otherwise), at least one domain + mail exchanger configured.
Observe the generated DNS records still include _mta-sts.<domain>.
curl -sk https://<server>/.well-known/mta-sts.txt → connection dropped; server log shows the panic above.
FoundationDB
Workaround
Set mode = testing — Display becomes serializable and the panics stop; but disabled-yet-advertised remains the underlying bug. Also note the _mta-sts TXT id= in already-written DNS zones is not refreshed when the policy changes.
Environment: Stalwart v0.16.13 (also present in v0.16.14 source), FoundationDB build, 2-node cluster, Linux x86_64.
Your analysis matches the current source. In crates/common/src/config/smtp/resolver.rs, Policy::try_parse maps PolicyEnforcement::Disable to Mode::None and still returns Some(policy) (falling back to SystemSettings.mail_exchangers/default_hostname when mx_hosts is empty, so it’s effectively never empty), and the Display impl for Policy only handles Mode::Enforce/Mode::Testing and hits unreachable!() for Mode::None:
match self.mode {
    Mode::Enforce => f.write_str("enforce")?,
    Mode::Testing => f.write_str("testing")?,
That’s a genuine defect: a disabled MTA-STS policy shouldn’t produce a Some(Policy) with Mode::None in the first place, and even if it can, Display panicking instead of handling none (a valid RFC 8461 value) is wrong. Your workaround of using mode = testing to stop the panics is correct as a stopgap, but it doesn’t fix the DNS records still being advertised when the feature is meant to be off.
This is a code-level bug rather than a documentation or configuration issue, so it isn’t something the docs can resolve. Flagging it here for a human/staff follow-up on the fix.
