Disabled strict "From"
I am not a Stalwart user yet. I want to ask, if the free version supports the “Disabled strict From” option, that I know from my current email server. It allows me to change the address-part before the @ of the from address in Thunderbird, while writing an email.
Because I am the only user of my email server, I like to use catch-all and also to change the address (to a not existing one). And those mails should be signed by dkim too.
Please excuse, not an English native speaker and also just a novice user of an email server in general.
Stalwart has no option with that exact name. You can get the same result with the default settings plus one change, and the free edition has everything you need.
The envelope sender check. When you log in and send, Stalwart checks the envelope sender (MAIL FROM). The setting mustMatchSender on the MtaStageAuth object controls this check, and it is on by default. With it on, you can only send as your own account name, your own addresses, or addresses of groups you belong to. Anything else is refused with 501 5.5.4 You are not allowed to send from this address. If you set it to false, an authenticated user can send with any sender address.
The From header. The docs say the From header, which is the address the recipient sees, is not checked by default. An authenticated user can put any address there. Thunderbird usually sets the envelope sender from the identity you picked, so the envelope check is the one you are most likely to hit. If you change the address and your server refuses it, turn mustMatchSender off.
DKIM. By default, the dkimSignDomain expression signs a message with the sender’s domain. This happens when you are logged in and the domain is hosted on your server. So if you change only the part before the @ and keep your own domain, the mail is still signed with that domain’s DKIM key. This works even if the address does not exist.
Catch-all. You set a catch-all address per domain with the catchAllAddress field. Unknown recipients on that domain are then delivered to it. The docs note that this can increase spam.
If you use a different domain in the From address, that domain must be hosted on your server to be signed by default.
