When a recipient returns a permanent delivery failure, Stalwart generates a delivery status notification (DSN) for the original sender.
If storing the DSN blob fails, Stalwart removes the original queued message even though the DSN was not durably queued. After storage recovers and Stalwart restarts, the queue remains empty.
The original SMTP submission was accepted, the message was not delivered, and the sender never receives a failure notification.
This was reproduced deterministically using an isolated Docker fixture. Healthy controls immediately before and after fault injection successfully generated and delivered DSNs with the same sender, recipients, routing, and rejection behavior.
Environment:
- Stalwart v0.16.21
- Source commit: e96200385781a6a9995a8b839ac27d6c75a983ee
- Official Docker image:
stalwartlabs/stalwart@sha256:93c574e52249c1ebf90061da2c4c0756a7b72abfcc1fec34506a03c2e38b5977 - Linux ARM64
- PostgreSQL 17 used as the data and blob store
- Internal directory
- No Enterprise license
- Verified-TLS LMTP delivery route
Stalwart must retain durable ownership of either:
- the original queued message and its pending failure-notification work; or
- a successfully queued DSN.
If queuing the DSN fails, Stalwart should retain or retry the original queue work. It must not mark the DSN as completed or retire the original message before the DSN is durably accepted.
Recovery should also handle a crash between successfully queuing the DSN and retiring the original message without losing the notification or generating uncontrolled duplicate DSNs.
Stalwart logs a blob-write failure while generating the DSN, but then removes the original queued message.
QueuedMessage/get returns an empty queue. After removing the injected storage fault and restarting Stalwart, the queue remains empty and no DSN is delivered.
The accepted original message is therefore neither delivered nor followed by a durable failure notification.
Configure:
- one registered envelope sender;
- two registered recipients;
- a verified-TLS LMTP delivery route;
- PostgreSQL as both the data and blob store;
- a one-second retry interval.
Submit a message using a nonempty envelope sender.
Have the controlled LMTP peer read DATA and disconnect before sending the final recipient responses.
Confirm through
QueuedMessage/getthat the accepted original message remains queued. -
Install the following fault injector in the disposable Stalwart PostgreSQL database. It rejects new blob writes while leaving existing blob reads and queue-metadata operations available:
CREATE FUNCTION proof_reject_blob() RETURNS trigger LANGUAGE plpgsql AS $$
BEGIN
RAISE EXCEPTION ‘proof: DSN blob write unavailable’;
END $$;
CREATE TRIGGER proof_reject_blob
BEFORE INSERT OR UPDATE ON t
FOR EACH ROW EXECUTE FUNCTION proof_reject_blob();
Change the LMTP peer to return permanent
550responses for the original recipients. -
Observe Stalwart logging
Failed to write bloband the injected PostgreSQL exception. -
Query
QueuedMessage/get. The original queued message and the expected null-envelope DSN are both absent. -
Remove the trigger and function:
DROP TRIGGER proof_reject_blob ON t;
DROP FUNCTION proof_reject_blob();
Restart Stalwart.
Query the queue repeatedly for five seconds, covering multiple configured retry intervals. The queue remains empty and no DSN is delivered.
Repeat without fault injection. The healthy control replaces the original queued message with a visible null-envelope DSN and successfully delivers it.
PASS: dsn-control-before: original replaced by visible queued DSN; DSN delivered
REPRODUCED: injected blob error observed; original and DSN absent from queue
PASS: dsn-control-after: original replaced by visible queued DSN; DSN delivered
PASS: storage/restart recovery delivers new DSNs; failed DSN remains absent
VALIDATED: pinned-release DSN loss under injected blob-write failure; release gate remains failed
