EmailSubmission: after local delivery `deliveryStatus.delivered` stays "unknown" and `smtpReply` stays "250 2.1.5 Queued"
A message sent to a mailbox on the same server is delivered within a second, undoStatus becomes final, but deliveryStatus.<rcpt>.delivered is unknown forever and smtpReply keeps the queue reply. Clients cannot show “delivered” even for internal mail, where the server knows the result.
RFC 8621, section 7 (deliveryStatus / delivered):
  • "yes": “The message was successfully delivered to the mail store of the recipient. The smtpReply property is final.”
  • "unknown": “The final delivery status is unknown, (e.g., it was relayed to an external machine and no further information is available).”
For a local recipient the final status is known, so after delivery delivered should be "yes" (or "no" on failure) with the final reply.
curl -s -u "[email protected]:$PASS1" -H 'Content-Type: application/json' https://mail.example.com/jmap/ -d '{
  "using": ["urn:ietf:params:jmap:core", "urn:ietf:params:jmap:mail", "urn:ietf:params:jmap:submission"],
  "methodCalls": [
    ["Email/set", {"accountId": "c", "create": {"e": {"mailboxIds": {"<drafts>": true}, "keywords": {"$draft": true},
      "from": [{"email": "[email protected]"}], "to": [{"email": "[email protected]"}], "subject": "probe now",
      "bodyValues": {"1": {"value": "probe"}}, "textBody": [{"partId": "1", "type": "text/plain"}]}}}, "e"],
    ["EmailSubmission/set", {"accountId": "c", "create": {"s": {"identityId": "<identity>", "emailId": "#e",
      "envelope": {"mailFrom": {"email": "[email protected]"}, "rcptTo": [{"email": "[email protected]"}]}}}}, "s"]]}'
["EmailSubmission/set", {"accountId": "c", "newState": "ssica", "created": {"s": {"id": "bq",
  "sendAt": "2026-10-21T11:00:04Z", "undoStatus": "pending"}}}, "s"]
The recipient has the message with receivedAt 2026-10-21T11:00:04Z. EmailSubmission/get one second and again 25 seconds later returns the same:
["EmailSubmission/get", {"accountId": "c", "state": "ssica", "list": [{"undoStatus": "final",
  "deliveryStatus": {"[email protected]": {"delivered": "unknown", "smtpReply": "250 2.1.5 Queued",
  "displayed": "unknown"}}, "sendAt": "2026-10-21T11:00:04Z", "id": "bq"}], "notFound": []}, "g"]
The exact requests and responses are under Actual Behavior.
Where it seems to come from:
crates/jmap/src/submission/set.rs stores Delivered::Unknown with “250 2.1.5 Queued” at creation. crates/jmap/src/submission/get.rs overrides it with live per-recipient status (Completed → Yes, PermanentFailure → No) only while the message is still in the queue (read_message_archive(queue_id)). Once the queue entry is removed after delivery, the stored creation-time value is returned again, so the final status is lost. Persisting the final per-recipient status into the EmailSubmission when the queue entry completes (or keeping it until the submission expires) would fix it.
Stalwart v0.16.27, Docker image stalwartlabs/stalwart:v0.16-alpine, default setup from the bootstrap wizard.
Your analysis matches what the code actually does. In crates/jmap/src/submission/get.rs, EmailSubmission/get only pulls live per-recipient delivery status from the still-queued message via read_message_archive(queue_id). While the queue entry exists it maps ArchivedStatus::Completed → Delivered::Yes and PermanentFailure → Delivered::No, with the real SMTP reply. But once the message leaves the queue (normal case, seconds after local delivery), that branch is skipped and the code falls back to queued_status = UndoStatus::Final for the submission itself, while the per-recipient delivery_status map simply keeps whatever was stored at creation time in set.rs (Delivered::Unknown, "250 2.1.5 Queued"). Nothing ever rewrites the stored EmailSubmission record with the final per-recipient outcome before the queue entry is purged, so the terminal result is lost even though the server computed it.
This is a genuine gap versus RFC 8621 behavior for local/internal delivery, not a configuration issue, so there’s nothing to adjust on your end to fix it. A staff member will need to look at persisting the final per-recipient status (success/failure + final SMTP reply) into the EmailSubmission object when the queue entry completes, as you suggested.
Fixed in v1.0.0, expected this week.
