Environment variables (%{env:VAR}%) not expanding after configuration migration
After migrating the configuration, environment variables utilizing the %{env:VAR}% syntax are no longer expanded by the parser and are instead interpreted literally.
Environment variable placeholders fail to resolve and remain as literal strings within the active configuration.
LDAP
An example of this configuration can be observed in the S3 bucket access key referenced from a secret:
Repository: arch-anes/self-hosted-services
File: self-hosted-services/charts/services/templates/stalwart.yaml
Commit: 6ee31ce22135d40900f34b028e418c3cb2625354
The %{env:VAR}% form was a macro of the pre-0.16 static TOML configuration; the 0.16 configuration lives in the database and doesn’t interpret that macro, so after migrating it’s kept as a literal string. That’s expected rather than a parser regression.
For an S3 access key or secret sourced from the environment, use the typed secret instead of the macro: set the field to an object with “@type”:“EnvironmentVariable” and a “variableName”, which resolves std::env at runtime. That’s the supported way to reference an env var in the current config model.
You’re right that there’s a documentation gap here and I’ll get that added.
I have tried the following self-hosted-services/charts/services/templates/stalwart.yaml at b2455d0ad79c2e4acc18dddb637308a1a6418190 · arch-anes/self-hosted-services · GitHub but got this error:
error: BlobStore: update failed for id singleton: error: invalidPatch |   Invalid value for property. |   Properties: accessKey
Is that reproducible with version 0.16.15 ?
Tested in v0.16.14 I believe. I don’t think anything regarding SecretKeyOptional changed in v0.16.15 to warrant a retry.
The accessKey was a string key which it did not accept environment variables. It was now converted to an enum which accepts environment variable names as well as file paths. The fix will be included v0.16.16.
Thanks for the quick patch @stalwart! Would it be possible to do something similar for MtaRouteRelay.authUsername and MtaRouteRelay.addressas well?
I could also submit a PR if you’d like.
It is technically possible but we want to avoid having enums for every single property (others might have similar ideas too). I recommend using the CLI or JMAP API to programmatically update the fields you need.
Got it. For anyone curious, I used `envsubst` to substitute the env vars before applying them: charts/charts/stalwart/values.yaml at d5c2f049a62f854b36d4dc9d6f102c53d44e94cd · arch-anes/charts · GitHub. Example usage of the chart: self-hosted-services/charts/services/templates/stalwart.yaml at b2848aab7e081f3691ed7dea48a54d3c3a449d16 · arch-anes/self-hosted-services · GitHub.
