I am the author of an individual Internet-Draft, **HMTP (HTTP Mail Transfer Protocol)**, which defines mail submission and server-to-server transfer over HTTPS:
In short: the message stays in RFC 5322 format inside a JSON envelope, requests are signed with HTTP Message Signatures using DKIM key records, endpoints are discovered with an SVCB record, errors are reported per recipient with a mapping to SMTP status codes, and SMTP remains as a fallback.
The draft is not adopted by any working group yet. The main question I keep hearing is whether server developers would be interested at all, so I would like to ask you directly:
**Would you consider experimental support for a small part of it, for example accepting HMTP transfer requests, behind a configuration flag and disabled by default?**
Even a short “no, because …” would be very useful feedback for the draft.
Thank you,
Dmitrii
