This is very useful, it addresses the recovery admin/HSTS lockout situation. Let me pull that section fully.
Found it. This is the migration proxy’s circuit breaker, and there is a documented way to force it back into service immediately.
Two separate problems are stacked here, and both have documented workarounds:
1. The legacy destination is marked down by the proxy’s health circuit breaker.
When TLS to a backend destination fails repeatedly, the migration proxy’s circuit breaker marks that destination down and rejects new connections for host_down_cooldown before probing again — this is exactly the “destination temporarily marked down” message. You can force it back into service immediately, without waiting for the ACME renewal to catch up, using the management API:
curl -k -H "Authorization: Bearer <token>" \
-X POST "https://127.0.0.1:9443/destinations/reset?destination=legacy"
Check GET /destinations first to confirm it’s the TLS handshake (not something else) causing the failures. See Destinations and Management API.
2. The underlying cause: the legacy backend’s certificate is genuinely expired, so every reconnect attempt fails TLS verification again.
Since this is an internal backend leg reached only by the proxy, you don’t need a trusted cert there. Either fix the ACME renewal, or as a temporary override set tls_allow_invalid_certs = true (or pin the specific cert with tls_pinned_cert_sha256) on that destination’s config so the proxy stops rejecting the connection on cert grounds while you sort out the certificate itself. Resetting the destination alone won’t help if the cert failure recurs on the very next probe. See Troubleshooting › A backend cannot be reached / TLS negotiation fails.
3. WebUI locked out by HSTS on an expired-cert host.
If the Stalwart admin WebUI itself is unreachable because the browser refuses the expired cert under HSTS, and the HTTP listener has been disabled, start the server with STALWART_RECOVERY_MODE=1, which re-enables the HTTP listener on port 8080 and accepts STALWART_RECOVERY_ADMIN regardless of directory/cert state, letting you sign in and fix the certificate or ACME provider config. Restart normally afterward. See Troubleshooting › HTTPS not yet reachable.
Once ACME renewal succeeds (or you replace the certificate manually as a Certificate object), reset the destination again if it’s still marked down.
