Messages sent over authenticated SMTP (587/465) are not saved to the sender’s Sent folder. SMTP-only apps such as WHMCS or website forms never get a copy. Ideally it would skip messages the client already saved (e.g. Outlook).
Would you consider a built-in option for this, or support for :fcc in the submission Sieve script (see Feature request: native save-sent for SMTP submissions via Sieve fcc · Issue #3180 · stalwartlabs/stalwart · GitHub)?
Thanks for Stalwart!
