FileNode/set allows creating multiple directories with the same role (violating the unique role constraint)
According to the JMAP FileNode specification (draft-ietf-jmap-filenode-20, Section on Roles), at most one Directory in an account can have a given role, and setting a role that another Directory already has should result in an invalidProperties error. However, the server currently fails to enforce this uniqueness constraint, allowing clients to create unlimited directories with the same role (e.g., home).
The server should check role uniqueness across the account. If a directory with the specified role already exists, any subsequent creation or update attempting to assign the same role to another directory should be rejected with an invalidProperties error.
The server successfully accepts the creation requests and allows an unlimited number of directories to be created with the exact same role (such as home) without returning any error.
  1. Send a FileNode/set request to create the first directory with "role": "home".
  2. Send a subsequent FileNode/set request to create another directory with "role": "home" in the same account.
  3. Observe that both directories are created successfully instead of the second one being rejected with an invalidProperties error.
“methodResponses”: [
“FileNode/query”,
“accountId”: “d”,
“queryState”: “sbe”,
“canCalculateChanges”: true,
“position”: 0,
“ids”: [
“b”,
“c”,
“d”,
“e”,
“i”,
“j”
“fnq_has_any_role”
“FileNode/get”,
“accountId”: “d”,
“state”: “sbe”,
“list”: [
“id”: “b”,
“parentId”: null,
“name”: “My files”,
“role”: “home”,
“@type”: “Directory”,
“created”: “2026-11-05T06:18:41Z”,
“myRights”: {
“mayRead”: true,
“mayAddChildren”: true,
“mayRename”: true,
“mayDelete”: true,
“mayModifyContent”: true,
“mayShare”: true,
“maySetMetadata”: true
“shareWith”: null
“id”: “c”,
“parentId”: null,
“name”: “My files”,
“role”: “home”,
“myRights”: {
“mayRead”: true,
“mayRename”: true,
“mayDelete”: true,
“mayShare”: true,
“shareWith”: null
“id”: “d”,
“parentId”: null,
“name”: “Trash”,
“role”: “trash”,
“myRights”: {
“mayRead”: true,
“mayRename”: true,
“mayDelete”: true,
“mayShare”: true,
“shareWith”: null
“id”: “e”,
“parentId”: null,
“name”: “Trash”,
“role”: “trash”,
“myRights”: {
“mayRead”: true,
“mayRename”: true,
“mayDelete”: true,
“mayShare”: true,
“shareWith”: null
“id”: “i”,
“parentId”: null,
“name”: “Home 3”,
“role”: “home”,
“created”: “2026-11-05T09:09:01Z”,
“myRights”: {
“mayRead”: true,
“mayRename”: true,
“mayDelete”: true,
“mayShare”: true,
“shareWith”: null
“id”: “j”,
“parentId”: null,
“name”: “Home 4”,
“role”: “home”,
“created”: “2026-11-05T09:16:33Z”,
“myRights”: {
“mayRead”: true,
“mayRename”: true,
“mayDelete”: true,
“mayShare”: true,
“shareWith”: null
“notFound”:
“fng_has_any_role”
“sessionState”: “f642002e”
v1.x
