- I created a folder using Bulwark, that uses JMAP. I can move mails into it and out from it.
- I connected thunderbird to stalwart using imaps
- the created folder is not visible in thunderbird, even though it exists and has mails in it.
If I create a folder in thunderbird, it is visible in bulwark.
Folders created through JMAP are visible in the IMAP client
Folders created through JMAP are not visible in the IMAP client
OIDC
