Fresh Install Rocky 10
Can’t log in after fresh install
Login
{“type”:“about:blank”,“status”:404,“title”:“Not Found”,“detail”:“The requested resource does not exist on this server.”}
Install and setup wizard complete
FoundationDB
Fresh install. Rocky 10. Foundationsdb flag used. Running foundation 7.4 or higher
Latest binary
Setup wizard all went well
DNS Automatically managed selected, hosted by CloudFlare
When I goto https:// mysite.ca/admin I get the error
Second time doing a full fresh format reinstall
The 404 on /admin almost certainly means the WebUI bundle was never downloaded. Here is what happens and how to fix it:
Root cause: The WebUI is not bundled into the binary. On first start, Stalwart fetches it from https://github.com/stalwartlabs/webui/releases/latest/. If that outbound HTTPS connection fails (firewall rule, Rocky 10 default policy, SELinux, or GitHub being unreachable), the bundle is never unpacked and every /admin route returns 404.
Steps to resolve:
  1. Check outbound connectivity from the server to github.com and objects.githubusercontent.com on TCP 443:
    curl -I https://github.com/stalwartlabs/webui/releases/latest/
    If this fails, a firewall or SELinux rule is blocking it.
  2. Check SELinux (very common on Rocky Linux). Either set the boolean to allow network connections for the service, or put SELinux into permissive mode temporarily to confirm:
    setsebool -P httpd_can_network_connect 1
    # or
    setenforce 0   # temporary test only
  3. Restart Stalwart after confirming connectivity so it retries the download:
    systemctl restart stalwart-mail
  4. Once the bundle downloads successfully, go to https://yourhostname/admin. If TLS is not yet working, you can also try http://<server-ip>:8080/admin (port 8080 is exempt from the hostname/TLS check) while you sort out certificates.
Note: If DNS/TLS for your hostname is not yet propagated, always use http://<host>:8080/admin first to verify the admin panel is working, then switch to the HTTPS URL.
Reference: FAQ - Why does /admin return 404 Not Found?
None of that worked. Tried it all
Check your logs after a restart for details.
talwart.service: Consumed 4.697s CPU time, 155.1M memory peak.
Jun 20 17:43:03 systemd[1]: Started stalwart.service - Stalwart.
That’s all I get with sudo journalctl -u stalwart -n 200
I tried to go to /var/log/stalwart but I get access denied. Run with sudo nothing happens
open your cockpit or firewall and make sure https allowed
i running stalwart with docker compose behind traefik in rocky linux 10 and all is fine
