How can I use stalwart-cli to write a script that shows me the size of each user's mailbox?
How can I use stalwart-cli to write a script that shows me the size of each user’s mailbox?
Now let’s check the query command doc for syntax examples.
Now I have enough to answer well.
Each Account object exposes a server-set usedDiskQuota field (in bytes), so you can query all User accounts and pull that field with stalwart-cli query:
stalwart-cli query account --fields name,emailAddress,usedDiskQuota --json \
  | jq -r '[.emailAddress, .usedDiskQuota] | @tsv'
This streams one JSON line per account (NDJSON), so it works fine even with many users. If you’d rather have a human-readable table, drop --json:
You can also filter, e.g. only accounts over a certain size:
stalwart-cli query account --where usedDiskQuota>=1000000000 --fields emailAddress,usedDiskQuota
Reference: Account object (see the usedDiskQuota field) and Searching and listing with the CLI.
printf “%-35s | %18s\n” “E-Mail” “Größe”
printf – “-----------------------------------±-------------------\n”
scli query account --fields emailAddress,usedDiskQuota --json
| jq -r ‘[.emailAddress, .usedDiskQuota] | @tsv
| while IFS=$‘\t’ read -r mail bytes; do
printf “%-35s | %18s\n” “$mail” “$(awk “BEGIN { printf “%.3f MB”, $bytes / 1024 / 1024 }”)”
done
