HTML to text keeps CSS from <style type="..."> and drops everything after <!---->
A lot of my marketing mail gets a broken preview in Stalwart. Some show raw CSS, others show nothing at all. I traced it to two bugs in the HTML-to-text conversion in mail-parser (html_to_text). Stalwart uses it for the preview of HTML-only messages and to index HTML parts for search.
  1. Style and script blocks are only skipped when the tag has no attributes. A style tag with type=“text/css” inside the body isn’t recognised, so the whole style sheet ends up in the text.
  2. An HTML comment that ends with more than two dashes never closes. The empty comment that many newsletters use is one example. Everything after it is lost.
  • A Wordfence activity report (HTML only) shows its CSS as the preview: “blockquote:before { content: none !important; } blockquote:after { …”
  • A Lieferando newsletter gets an empty preview, because an empty comment in its head swallows the rest of the HTML part.
Style and script blocks are skipped whatever attributes the tag has. A comment ends correctly no matter how many dashes come before the closing bracket, which is how browsers handle it.
For the test messages below, the preview should be “Hello world” or “Before Hello world”.
HTML body, then the preview Stalwart returns:
<style>p { color: red; }</style><p>Hello world</p>
  -> Hello world  (correct)
<style type="text/css">p { color: red; }</style><p>Hello world</p>
  -> p { color: red; }Hello world
<script type="text/javascript">var x = 1;</script><p>Hello world</p>
  -> var x = 1;Hello world
<p>Before</p><!----><p>Hello world</p>
  -> Before
<p>Before</p><!-- note ---><p>Hello world</p>
  -> Before
  1. Deliver or import this message:
To: [email protected]
Subject: style test
MIME-Version: 1.0
Content-Type: text/html; charset=UTF-8
<html><head><title>t</title></head><body><style type="text/css">p { color: red; }</style><p>Hello world</p></body></html>
  1. Fetch it with Email/get and ask for the preview property. You get “p { color: red; }Hello world”. Remove type=“text/css” and you get “Hello world”.
  2. Do the same with the body from the last two examples above. The preview is just “Before”.
  • In mail-parser 0.11.9 (src/decoders/html.rs), the tag name is only compared while tag_token_pos is 1. A tag with any attribute never matches, so in_style and in_script stay false. A comment only ends when exactly two dashes come before the closing bracket (comment_pos == 2).
  • It still happens on mail-parser main, the unreleased 1.0.0 rewrite. I built it and ran the same input.
  • Search indexing (crates/email/src/message/index/search.rs) and search snippets use the same function. So in HTML-only messages, text after such a comment probably isn’t searchable either. I haven’t tested that part.
Built from source
This is a well-documented, specific bug report with a detailed reproduction, root-cause analysis in mail-parser’s html.rs, and confirmation it affects both preview and search indexing in Stalwart. This is exactly the kind of issue a human engineer should triage rather than something I can resolve via docs.
Thanks for the detailed writeup and reproduction steps. This looks correctly diagnosed: Stalwart’s HTML-to-text conversion (used for both the preview property and for indexing/snippets of HTML-only parts) comes from the mail-parser crate, not from code in this repo, so the two bugs you found are upstream in mail-parser’s html.rs decoder rather than something configurable in Stalwart. That matches what the search/snippet code here does: search.rs, parse.rs, and snippet.rs all call into the same html_to_text routine for preview and search-index purposes, so a fix would need to land in mail-parser and then be picked up by a Stalwart release.
Since this is a genuine parsing bug rather than a documentation or configuration gap, there’s nothing to adjust on your end (no setting controls this behavior). I’ll leave this for a human maintainer to confirm and track against the mail-parser dependency.
Fixed
Thank you very much.
