When an organizer sends many messages to the same internal colleague, the default inbound throttle “Sender address to recipient throttle” (key senderDomain + rcpt, 25 per hour) starts answering 452 4.4.5 Rate limit exceeded, try again later. After that, CalendarEvent/set with sendSchedulingMessages: true still succeeds, but the invitation never arrives: no event and no message at the attendee, no DSN and no notification for the organizer, and it is never retried.
A temporary (4xx) failure is temporary (RFC 5321, section 4.2.1): the iMIP message should be retried later (task result “temporary”), or at least the organizer should learn that it was not delivered (for example a DSN, or a CalendarEventNotification). Silent loss of an invitation is the worst outcome for scheduling.
The iMIP task logs the Calendar(ItipMessageError) event (“Server rejected RCPT-TO: 452 4.4.5 …”) and returns success; the message is gone.
- Default inbound throttles (fresh install creates “Sender address to recipient throttle”: 25 / 1h, key
senderDomain+rcpt). - As
[email protected]send 25 or more messages to[email protected]within an hour (EmailSubmission/set, any content). - As user1, create an event with user2 as attendee:
curl -s -u "[email protected]:$PASS1" -H 'Content-Type: application/json' https://mail.example.com/jmap/ -d '{
"using": ["urn:ietf:params:jmap:core", "urn:ietf:params:jmap:calendars"],
"methodCalls": [["CalendarEvent/set", {"accountId": "c", "sendSchedulingMessages": true, "create": {"ev": {
"calendarIds": {"b": true}, "@type": "Event", "title": "Planning", "uid": "[email protected]",
"start": "2026-11-03T10:00:00", "timeZone": "Etc/UTC", "duration": "PT1H",
"organizerCalendarAddress": "mailto:[email protected]",
"participants": {
"o": {"calendarAddress": "mailto:[email protected]", "roles": {"owner": true, "attendee": true}},
"a": {"calendarAddress": "mailto:[email protected]", "roles": {"attendee": true}, "expectReply": true}}}}}, "s"]]}'
- The response is a normal
created. user2 gets neither the event (CalendarEvent/querywithfilter.uid) nor an iMIP message, also after waiting. The server log showssmtp.rate-limit-exceeded; per the source the iMIP task then emitsCalendar(ItipMessageError).
We hit this on our test server (v0.16.27) while running automated tests that send a few dozen messages to one test user; invitations then disappeared without any error on the organizer side.
Same class as CalendarEvent/set silently drops the invitation when the account lacks calendar-scheduling-send (fixed in 0.16.21), but a different code path: here the permission is fine and the drop happens in the iMIP task.
Where it seems to come from:
crates/services/src/task_manager/imip.rs, send_imip(): after handle_rcpt_to(), if session.has_failed() the code emits ItipMessageError and returns from the closure; the task then returns TaskResult::Success. The same happens for a rejected MAIL FROM or DATA. A 4xx reply could map to TaskResult::temporary(..) so the task manager retries it, and a 5xx reply to a bounce or notification for the organizer.
Side question: should the default “Sender address to recipient throttle” apply to authenticated local senders and internal deliveries at all? 25 messages per hour from one colleague to another is easy to reach in a normal office.
Stalwart v0.16.27, Docker image stalwartlabs/stalwart:v0.16-alpine, default setup from the bootstrap wizard.
