Installation problem
When trying to install stalwart on OpenSuse 16 (with SELINUX activated) I cannot finish the wizard.
Finished installation
Error message “The configured data store is incompatible with the configured directory”. Installation can not be finished. Message appears regardless on what I configure as Data store, directory or any other of the stores.
Steps:
  1. Download “install.sh”
  2. run install.sh
  3. access http://:8080/admin and login with credentials given in log
  4. create a database called stalwart in my SQL Server, add a user with full privileges onto that database
  5. Setting Main Datastore on mySQL, enter correct credientials
  6. Leave everything as default except Directory.
  7. Set directory to MySQL (new database, set up as the main data store database)
  8. Finish Setup.
No log file written at that point, no errors in journald nor in audit.log
MySQL
MySQL
MySQL
SQL
Fixed in v0.16.20 (yet to be released).
Hi and thank you for that answer. I was really starting to think I am incapable to configure… Any time estimate for the release?
It will be released today or tomorrow.
Thank you for that. I can now confirm that it works. At least to some extend, I will have some other questions soon :slight_smile:
