Issue uploading spam sample
When trying to create a new spam sample, no error is shown, but sample is not saved. Browser development console show jmap call returns 200 to /jmap POST “Blob/get”. Blob is 7kb in size. Response is:
    "methodResponses": [
            "error",
                "type": "unknownMethod",
                "description": "Method Blob/upload requires capability urn:ietf:params:jmap:blob which is not present in the \"using\" property."
            "blob-0"
            "error",
                "type": "invalidResultReference",
                "description": "Invalid reference to non-existing object \"temp-blob-0\" from \"new-0\""
            "set-0"
    "sessionState": "a4824225"
Spam sample created and listed.
Sample not created.
  1. Open “Account”
  2. Open “Spam Samples”
  3. Do “Create sample” (no account, just message)
None in server log.
This is a confirmed bug in the WebUI. The WebUI’s JMAP client (src/services/jmap/client.ts) already includes urn:ietf:params:jmap:blob in its using array – but the error message says the Blob/upload call is being sent without that capability declared. This points to a specific code path (the spam sample upload flow) that is making a JMAP request that does not go through the standard jmapRequest wrapper, and therefore doesn’t include the full using array with the blob capability.
The error chain is:
  1. Blob/upload is sent without urn:ietf:params:jmap:blob in the using property – server rejects it with unknownMethod.
  2. A second method call that references the blob result (temp-blob-0) then fails with invalidResultReference because the blob was never created.
This is a WebUI bug – the spam sample upload form is constructing or dispatching its JMAP request in a way that omits the blob capability from the using array. The server behavior is correct per the JMAP spec (RFC 9404).
Workaround: There is no known client-side workaround at this time. The fix needs to be applied in the WebUI code so that all Blob/upload calls go through the standard request path that includes the full using array.
A human maintainer or community member will follow up on the fix.
You are on an old version of the WebUI, upgrade to fix it.
This does not seem to be solved in the latest version of the WebUI.
