After restart:
2026-10-19T10:57:39Z INFO Blocked IP address (security.ip-blocked) listenerId = “submission”, localPort = 587, remoteIp = 31.70.76.30, remotePort = 52730
2026-10-19T10:57:54Z INFO Blocked IP address (security.ip-blocked) listenerId = “submission”, localPort = 587, remoteIp = 31.70.76.30, remotePort = 54985
Binary (FreeBSD)
Found it. There is documented “Action” to reload blocked IPs without a restart. Let’s check the docs page for how to actually trigger this.
I have enough to answer confidently.
Adding a BlockedIp record through the WebUI does not by itself refresh the live in-memory blocklist used by the SMTP/IMAP listeners; that list is only picked up automatically when the record is created through the block_ip path (e.g. automatic fail2ban). For entries added manually via the Settings UI, you need to trigger the ReloadBlockedIps Action afterwards so the server rereads the blocked IP list without a restart.
You can do this from the WebUI’s server Actions screen (create a new Action of type “Reload: Blocked IPs list”), via stalwart-cli create action/reload-blocked-ips, or by calling Action/set with @type: "ReloadBlockedIps" over JMAP. This reloads the blocklist applied by the inbound filters immediately.
@Corne is correct. Blocked IPs you add by hand are written to the registry, and the running server picks them up when you run the “Blocked IPs list” reload under Management › Actions, or stalwart-cli create Action/ReloadBlockedIps. No restart needed. Bans the server adds on its own apply immediately; it’s manual edits that need the reload (Overview | Stalwart).
