Creating a masked address with emailDomain fails with forbidden / “The specified domain is not valid for this account.” for every domain, including the domain of the account’s own primary address, when the account has aliases on more than one domain.
Creating without emailDomain works and picks the primary address’s domain.
Account
[email protected]with an alias[email protected](both domains local). -
Logged in as that account:
stalwart-cli create MaskedEmail --field emailDomain=example.com→
forbidden, “The specified domain is not valid for this account.” Same forexample.org. -
Without the field:
stalwart-cli create MaskedEmail --field description=test→ created on
example.com.
crates/jmap/src/registry/mapping/masked_email.rs, around line 78:
.filter(|domain| {
account
.addresses
.iter()
.all(|addr| addr.domain_id == domain.id)
.all() requires every address on the account to be in the requested domain, so any account with addresses on two domains can never pass. The intent looks like “the account has an address on this domain”, which is .any():
.any(|addr| addr.domain_id == domain.id)
The existing test in tests/src/system/delivery.rs only uses an account whose addresses are all on one domain, so it doesn’t catch this.
Separately (possibly intended)
Creating as an admin with --field accountId=<id> returns invalidForeignKey for a valid account id, so masked addresses can only be created by logging in as the owning account. If admins are meant to be able to create them for other accounts, that looks like a second bug.
