When Trying to Migrate with Migration Tool 1.0.5 execution on old server from mariadb (mysql) to new mariadb (mysql)
2026-11-01T18:55:13.349880Z ERROR stalwart_migrate: command failed error=the v1 --target is a v0.16 store; the target must be a separate, new store
But it is an empty DB.
MariaDB [stalwart]> show tables;
Empty set (0,002 sec)
The Connection settings are correct. If I stop the new mariadb server then:
2026-11-01T19:04:33.023345Z ERROR stalwart_migrate: command failed error=cannot check the v1 target: fatal error: cannot check that the v1 target is a new empty store, refusing to open it: transient error: MySQL error (store.mysql-error): reason = Input/output error: Input/output error: Connection refused (os error 111), causedBy = vendor/v1/crates/store/src/dispatch/store.rs:296
When I restart mariadb:
2026-11-01T19:05:54.082550Z ERROR stalwart_migrate: command failed error=the v1 --target is a v0.16 store; the target must be a separate, new store
MySQL
MySQL
MySQL
