Milter: header values that are not valid UTF-8 are sent as empty strings
Stalwart sends a header whose name or value is not valid UTF-8 to the milter (SMFIC_HEADER) with an empty value. The milter sees the header, but not its content.
The milter protocol carries header names and values as NUL-terminated byte strings and has no UTF-8 requirement. Postfix and Sendmail pass the raw bytes through. Stalwart should send the header bytes as received.
Tested on v1.0.0 with a minimal milter (protocol v6) that logs each frame. The message was:
To: [email protected]
Subject: Caf\xe9 au lait        <- raw ISO-8859-1 byte 0xE9
X-Ok: plain ascii
The milter received:
HEADER b'Subject' b''
HEADER b'X-Ok' b'plain ascii'
The delivered message still has the original Subject: Caf\xe9 au lait, so a filter scores or acts on something different from what the recipient gets. Raw 8-bit headers are not standards-conformant, but they are common in spam and in legacy mail, which is where a filter needs to see them most.
Cause
crates/smtp/src/inbound/milter/message.rs (v1.0.0, around line 271):
client.headers(message.headers().iter().map(|(k, v)| {
        std::str::from_utf8(k).unwrap_or_default(),
        std::str::from_utf8(v).unwrap_or_default(),
unwrap_or_default() turns an invalid header into "". MilterClient::headers (client.rs:222) takes AsRef<str>, but only to call .trim().as_bytes(), so it could take &[u8] and send the bytes unchanged (trimming ASCII whitespace with trim_ascii()).
The reply direction has the same restriction. read_nul_terminated (protocol.rs:272) uses String::from_utf8(buf).ok(), so an SMFIR_ADDHEADER / SMFIR_CHGHEADER / SMFIR_INSHEADER whose value is not UTF-8 fails to parse.
See “Actual Behaviour”
v1.x
The code you quoted matches the current source, so I could confirm your analysis.
In crates/smtp/src/inbound/milter/message.rs, around lines 271–276, the header list sent to the milter is built with std::str::from_utf8(k).unwrap_or_default() for the name and the same call for the value. Any header whose bytes aren’t valid UTF-8 is therefore sent as an empty string, as you describe.
In crates/smtp/src/inbound/milter/protocol.rs, the reply parser calls read_nul_terminated for the SMFIR_ADDHEADER name and value (around lines 205–207). I didn’t open that function, so I haven’t checked your claim that it uses String::from_utf8(buf).ok(). The call sites do return String values, which fits your description of the reply-side parsing failing on non-UTF-8 bytes.
The docs I searched don’t mention this limitation or a workaround, so I can’t offer a setting that changes the behaviour. A human will follow up on whether to change the milter client to pass raw bytes in both directions.
On the sending side, MilterClient::headers only needed each header as text to trim it, so the server forced every name and value through UTF-8 and sent an empty string when that failed. It now takes the raw bytes, trims ASCII whitespace and sends them as received, so Subject: Caf\xe9 au lait reaches the milter byte for byte. A regression test pushes a raw 0xE9 subject through a mock milter and checks the exact bytes it saw.
This ships in the next weekly Stalwart release.
I left the reply direction alone. An SMFIR_ADDHEADER, SMFIR_CHGHEADER or SMFIR_INSHEADER with a non-UTF-8 value is still rejected when it’s parsed. The milters people usually run here add ASCII headers, and supporting raw bytes in replies would mean changing how header modifications are represented across the MTA, so it didn’t make sense to fold into this fix.
