Monitoring Overview is blank while other dashboards work — Stalwart 1.0.2 Enterprise
The Monitoring → Overview page remains blank, while all other monitoring dashboard pages display data correctly.
The server is running Stalwart 1.0.2 Enterprise. A runtime query confirms “edition”: “enterprise”, and Enterprise AI settings are accessible.
The installation was migrated from 0.16.27 to 1.0.0, subsequently updated to 1.0.1 and then to 1.0.2. The installed WebUI version has not yet been determined.
Environment: Ubuntu 26.04.1 LTS, official Linux binary managed by systemd, MariaDB 11.8.6, and HTTPS access through Caddy.
The Overview page should display its dashboard tiles and available monitoring data. If data or permissions are missing, an explanatory message should be shown rather than a blank content area.
The Overview content area remains blank. Switching to other monitoring dashboard pages displays data correctly.
The problem is also reproducible in a private browser window. No clear application JavaScript error explaining the blank page has been identified.
Normal mail sending and receiving continue to work.
  1. Sign in to the Stalwart WebUI with an administrator account.
  2. Open Monitoring → Overview.
  3. Observe that the overview content area remains blank.
  4. Switch to another monitoring dashboard and observe that data is displayed.
  5. Repeat in a private browser window: Overview remains blank.
No relevant server-side error has been captured for this specific page load. Trace logging has not been enabled.
Browser developer tools showed these HTTP responses:
GET /api/schema
HTTP 302 Found
Content-Length: 0
GET /logo
HTTP 404 Not Found
The response from the final redirected schema URL has not been verified. The 302 response is therefore not evidence of a schema failure. Whether the logo request is related is unknown.
v1.x
MySQL
MySQL
MySQL
Browser: Brave / Chromium 156 on Linux.
Stalwart is managed by systemd and uses /etc/stalwart-v1/config.json. Caddy terminates HTTPS and proxies requests to Stalwart at 127.0.0.1:18081.
Enterprise activation has been confirmed at runtime. All 13 administrator permissions added in Stalwart 1.0.2 were subsequently added to the System Administrator role and verified. The administrator signed out and signed back in afterward.
Other monitoring dashboard pages display data, so this does not appear to be a complete monitoring outage.
Please advise which minimal diagnostic information would help distinguish a WebUI rendering issue, a WebUI/server schema mismatch, or an Overview-specific configuration requirement.
Overview is blank because your WebUI bundle is older than the server. In 1.0.2 the Overview dashboard moved to a new tile layout (stat, chart, headline and ranking tiles) that only WebUI 2.0.4 knows how to draw. An older WebUI finds none of the old-style cards or charts in it and renders an empty area, while the other dashboards still use the old format, so they look fine.
The server keeps the downloaded WebUI in the blob store and only fetches it again once the stored copy expires (90 days by default), so an upgraded server keeps serving the previous release. You can force the download now from Management › Actions with an “Update applications” action, or with the CLI:
stalwart-cli create Action/UpdateApps
Then reload the page. Details on how bundles are cached and updated: Updates | Stalwart
The /logo 404 is unrelated; it just means no custom logo is configured.
+1 for the minimum-version check. It keeps coming up: after the Overview dashboard in 1.0.2 (Monitoring Overview is blank while other dashboards work — Stalwart 1.0.2 Enterprise), passkey registration in 1.1.0 needs WebUI 2.0.5, and an upgraded server keeps serving its cached bundle, so passkey creation shows only the raw “Client Data / Attestation Object” fields (same as Passkey Registration not working as documented; we hit it too). Each release that depends on new WebUI features turns into the same forum question.
One more detail: on an install migrated from 0.16 with stalwart-migrate, the Application resourceUrl points to .../webui/releases/latest/download/webui.zip, while new 1.1.0 installs use .../releases/download/v2/webui.zip. Migrated servers will therefore pick up a future WebUI 3 on their own. Worth a note in the upgrade docs, or a one-time rewrite to v2.
