MX record lookup with more than two MX (unreachable) records
Only the first two MX records seem to be tried during sending
TLS reports are successfully sent during a test with https://email-security-scans.org
All MX records should be tried in order of the priority, not only the first two.
Email to
tlsrpt@dzifx5ywhk5qte8ow8ne1f77h9xueo.uniq.measurement.email-security-scans.org
is queued in the outgoing queue until expiry.
The MX discovery from stalwart (according to admin/Management/x:Trace/OutboundDelivery) lists only the first two MX records:
dzifx5ywhk5qte8ow8ne1f77h9xueo.uzone.measurement.email-security-scans.org and dzifx5ywhk5qte8ow8ne1f77h9xueo.umx.v6only.measurement.email-security-scans.org - both of them are disabled by design.
The third one is not used:
delv -t MX dzifx5ywhk5qte8ow8ne1f77h9xueo.uniq.measurement.email-security-scans.org
; fully validated
dzifx5ywhk5qte8ow8ne1f77h9xueo.uniq.measurement.email-security-scans.org. 273 IN MX 10 dzifx5ywhk5qte8ow8ne1f77h9xueo.uzone.measurement.email-security-scans.org.
dzifx5ywhk5qte8ow8ne1f77h9xueo.uniq.measurement.email-security-scans.org. 273 IN MX 20 dzifx5ywhk5qte8ow8ne1f77h9xueo.umx.v6only.measurement.email-security-scans.org.
dzifx5ywhk5qte8ow8ne1f77h9xueo.uniq.measurement.email-security-scans.org. 273 IN MX 50 mail.measurement.email-security-scans.org.
After talking to one of the maintainers of the email-security-scans.org test-suite, I got the following response:
i think this is a stalwart bug; The zone for receiving TLS-RPT has
three MX, of which only the lowest priority MX is actually deliverable.
It seems like stalwart is aborting after two attempts; You are the
second one writing me about this.
Might be worthwhile to file a bug there.
  1. Start test via https://email-security-scans.org.
  2. Wait until TLS-reports are scheduled for sending.
  3. See the unsuccessful retries in admin/Management/x:Trace/OutboundDelivery.
v1.x
This is a configured limit, not a bug. A new installation’s mx route sets maxMxHosts to 2. Each delivery attempt tries only that many MX hosts, taking the lowest preference values first. With a limit of 2, a domain’s third and later MX hosts are never tried. That matches what you see: the two unreachable hosts (priority 10 and 20) use up the limit, so mail.measurement.email-security-scans.org (priority 50) is never contacted.
To fix it, raise maxMxHosts on your mx route to 3 or more. You can do this in the WebUI under the MTA routes settings. The route object looks like this:
  "@type": "Mx",
  "name": "mx",
  "maxMxHosts": 5,
  "maxMultihomed": 2,
  "ipLookupStrategy": "v4ThenV6"
Keep your existing values for the other fields. The schema reference lists a default of 5 for maxMxHosts, but the docs say the initial mx route is created with 2. Check what your route currently has.
Docs:
