Stalwart 0.16.22 with the official spam-filter ruleset v3.0.1 has a case-normalization mismatch between extracted URLs and HTTP lookup keys.
The official URL rules use:
- STWT_PHISHED_OPEN: key_exists(‘stwt_openphish’, url)
- STWT_PHISHED_TANK: key_exists(‘stwt_phishtank’, url)
UrlParts::new() sets url to url_original.trim().to_lowercase(), lowercasing the entire URL, including its path and query.
However, the HTTP lookup loader preserves case in both List entries and CSV keys. HttpStore::contains() then performs an exact contains_key() lookup.
Consequently, a URL containing uppercase characters in its path or query can fail to match the identical URL present in the phishing feed.
The rules and lookup configurations were confirmed enabled on our server. This report is based on source inspection and an isolated reproduction of the lookup mismatch, not an end-to-end SMTP test.
An extracted URL that exactly matches a loaded OpenPhish or PhishTank entry should trigger PHISHED_OPENPHISH or PHISHED_PHISHTANK respectively, including when the path or query contains uppercase characters.
URL handling should preserve potentially significant case in the path and query, rather than indiscriminately lowercasing the complete URL.
For a feed entry such as:
https://example.invalid/Account/Verify?Token=AbC123
the rule looks up:
https://example.invalid/account/verify?token=abc123
The HTTP lookup contains the original key, so the lowercased lookup fails unless that separate lowercase key also exists.
This causes a missed phishing-list signal. Other spam checks may still detect the message; this report does not claim that the message necessarily reaches the Inbox.
In a freshly downloaded OpenPhish feed, 72 of 300 entries changed when lowercased and had no corresponding lowercase key. This is a snapshot of a changing feed, not a fixed affected percentage.
Source-level reproduction, without contacting any phishing destination:
Use this synthetic feed entry:
https://example.invalid/Account/Verify?Token=AbC123 -
Store it unchanged as a List entry, or as the URL key in a CSV lookup.
Apply the transformation used by UrlParts::new():
trim the URL and lowercase the complete string. -
Perform the exact key lookup used by HttpStore::contains().
The original URL matches; the transformed URL does not.
Minimal Python illustration of the verified data flow:
import csv
import io
url = "https://example.invalid/Account/Verify?Token=AbC123"
list_keys = {url.strip()}
csv_data = "phish_id,url\n1," + url + "\n"
csv_keys = {
row["url"]
for row in csv.DictReader(io.StringIO(csv_data))
for name, keys in [("List", list_keys), ("CSV", csv_keys)]:
print(name, url in keys, url.strip().lower() in keys)
Output:
List True False
CSV True False
This illustrates the source-level mismatch; it is not a Stalwart integration test.
No SMTP trace was captured. The evidence is the source-level lookup mismatch described above, rather than a server error or exception.
Relevant source in v0.16.22:
URL lowercasing:
Expression variable mapping:
Exact lookup and case-preserving feed loading:
