When trying to compile for Arch Linux, the OSS build fails due to SCIM errors.
Running the below causes issues:
# remove refs to enterprise code
python resources/scripts/ossify.py crates/
# prefetch dependencies
cargo fetch --locked --target host-tuple # fails here
# compile binary
cargo build --release --frozen -p stalwart --no-default-features --features"sqlite postgres mysql rocks s3 redis azure nats"
Processing Rust files in: crates/
Found 957 Rust files
Summary:
- 52 files were completely removed
- 117 proprietary snippets were removed from 50 files
error: failed to load manifest for workspace member `/build/stalwart/src/stalwart/crates/main`
referenced by workspace at `/build/stalwart/src/stalwart/Cargo.toml`
Caused by:
failed to load manifest for dependency `http`
Caused by:
failed to load manifest for dependency `scim`
Caused by:
failed to parse manifest at `/build/stalwart/src/stalwart/crates/scim/Cargo.toml`
Caused by:
no targets specified in the manifest
either src/lib.rs, src/main.rs, a [lib] section, or [[bin]] section must be present
Built from source
