Query about a very specific Stalwart configuruation
I am wondering whether the following very specific Stalwart configuration is possible:
(1) Runs under Debian 13 (linux)
(2) Provides only IMAP services without any SMTP services
(3) Manages around 15 different IMAP accounts all of whose email addresses I specify
(4) All IMAP accounts keep their emails in one, single, centralized Maildir folder tree on the server machine, and not in separate Maildir instances in separate HOME directories
(5) SSL/TLS access via port 993 is necessary for all accounts; port 143 access is also acceptable, but not necessary
All five of these criteria must be manageable under the stalwart configuration that I desire. I cannot accept only a subset of these criteria.
Thank you very much in advance.
What do you mean by a Maildir? Stalwart uses an internal database and blob store. I think the other requirements are pretty straightforward.
Oh … I just wrote “Maildir” because I couldn’t think of a better name at the moment I was entering this question. The format of the centralized mail db is totally irrelevant to me, and the internal database and blob store is totally acceptable to me.
Given that all this is do-able, can someone point me to the appropriate documentation for installing stalwart and which covers all of my criteria?
I assume just Overview | Stalwart
Everything else is pretty obvious. IMAP only = do not expose the other port(s). You can provide your own SSL cert in the settings.
OK. I’ll just block the SMTP-related port(s) and go with those “Overview” and “Stalwart” docs. I vaguely remember long ago setting up stalwart under a different linux version and getting stuck and confused by some of the instructions in those standard docs.
I’m hoping that this won’t happen now, but if it does, I’ll just ask for help in this forum.
Thank you very much for all your help!!!
Blocking the ports is one way, u can also disable the listeners in the stalwart ui after the install is complete.
Perhaps u should consider useing the dockerimages, so the setup is always the same, regardless of the linux version/distribution.
Once you are installed, just delete the listeners you don’t want. As you can see here I’ve deleted POP3 as I don’t need it.
