How to add an attribute for disk quota on LDAP in Version 16.x
Let me look up how LDAP quota configuration works in Stalwart.
Stalwart does not read disk quota attributes from LDAP. The documentation is explicit on this point:
“Quota values are held exclusively on the Account and Tenant objects; the server does not read disk-quota attributes from external directories. Even when authentication is delegated to LDAP or SQL, quotas must be configured through the Account object (or the Tenant object for tenant-wide caps) from the WebUI or the JMAP API.”
There is no attrQuota or equivalent LDAP attribute mapping available – the LDAP attribute list deliberately omits per-account disk quota. Quotas must be set directly on each Account object (via the WebUI under Management > Directory > Accounts, or via the JMAP API) using the maxDiskQuota key in the account’s quotas map.
Relevant docs:
in 15.x it was possible to dedicate an LDAP Attribute for this
You’re right that this was possible in 0.15. In the current version, that behavior was removed – quotas are no longer read from LDAP attributes at all, regardless of what was previously configured. The docs are explicit that quota values are held exclusively on the Account and Tenant objects, and must be set through the WebUI or JMAP API.
If you have many accounts to migrate, the JMAP API would be the practical path for bulk-setting maxDiskQuota on each Account object, rather than configuring them one by one in the WebUI.
ok no problem, i can live with that
