Redis Sentinel ignores TLS configured via rediss://
When RedisSentinel is configured with rediss:// URLs, Stalwart connects to both the Sentinel nodes and the discovered Redis master using plain TCP.
Credentials configured through authSecret and sentinelSecret work, but the connections are not encrypted. This makes Redis Sentinel unusable when Sentinel and Redis nodes require TLS.
rediss:// enables TLS for both Sentinel and Redis data-node connections.
both connections use unencrypted TCP.
Elasticsearch
Looking at the current source, this is confirmed as a real bug in the Redis Sentinel implementation, not just a documentation gap.
In open_sentinel() (crates/store/src/backend/redis/mod.rs), each Sentinel URL is parsed only to extract its addr() (host/port) via into_connection_info(), and the resulting plain socket addresses are handed to SentinelClientBuilder. The rediss:// scheme, which carries the “use TLS” signal, is discarded at that point, so neither the Sentinel connections nor the discovered master connection ever get a TLS context — unlike the single-node (RedisStore::open_single) path, which builds Client::open(config.url) directly and does honor rediss://.
So your observation is accurate: TLS configured via rediss:// is effectively ignored for Sentinel-mode deployments in the current code.
Fixed in v0.16.20 (yet to be released).
