The Zone file correctly shows example.com. IN MX 10 mail.example.com..
Set the correct DNS record.
DNS Record on example.com for key and type MX is mail.example.com.example.com.
This looks like a bug in how the Scaleway DNS provider integration composes record names rather than a configuration mistake on your side. Stalwart’s DNS record builder generates the MX exchange target correctly (mail.example.com.), and the zone file that Stalwart computes internally shows the correct value, but the Scaleway API client appears to append the zone origin (example.com) to the record name a second time when submitting it to Scaleway’s API, resulting in mail.example.com.example.com. being sent instead of the plain mail.example.com.. There’s nothing in the current docs about a workaround for this (e.g. no config knob to disable the extra suffixing for Scaleway specifically), so this isn’t something you can fix from your side via configuration.
Given the specificity of this, a human/staff member should confirm and look at the Scaleway provider integration directly.
