Stalwart 1.0.3 (8b32686). Not a vulnerability report: the registry is admin-only.
The Redis coordinator takes only url, so a password has to go in the URL. RedisCluster and RedisSentinel have authSecret, which can point at an environment variable or a file (crates/registry/src/schema/structs.rs:4833-4909). The Redis in-memory store uses the same struct.
Tested on a running node:
| Object | Result |
x:Coordinator/set, Redis with authSecret as EnvironmentVariable |
Refused: invalidPatch, “Invalid property”, authSecret. Object unchanged |
x:InMemoryStore/get, RedisSentinel with authSecret as EnvironmentVariable |
Reply shows the variable reference, not the password |
Could Redis take authSecret too? Then its password could come from an environment variable or file, the same as the other two variants.
Tested and written with AI help.
