I want to send emails from address [email protected] while authenticated as [email protected].
The only settings I found that could do this is at SMTP AUTH Stage → Must match sender. But I don;t want to allow it for all. Can anyone point me to where I can find the syntax to write an exception ?
Current outcome:
The following From address failed: [email protected] : MAIL FROM command failed,You are not allowed to send from this address.
Add the exception as an expression on mustMatchSender under SMTP AUTH Stage settings, rather than disabling the check globally. The field is an Expression that can inspect the sender and authenticated_as variables, so you can allow a specific authenticated account to send as a specific alternate address while keeping the default true behavior for everyone else:
This evaluates to false (no match required, i.e. allowed) only for that specific authenticated user/sender pair, and falls back to true (must match) for everyone else. You could also add sender as an alias/email of the net-mbox account instead, which would satisfy the default mustMatchSender: true check without needing an exception at all, if that better fits your directory setup.
