When trying to send via submission service thunderbird reports error: Sending of the message failed. The message could not be sent because the connection to Outgoing server (SMTP) submission.mxbox.cloud timed out. Try again. Message gets delivered to the recipient but doesn’t get saved in “Sent”
Stalwart returns 250 after accepting the message body.
Thunderbird received 354, sent a 708-byte body, then timed out after 100 seconds without a final reply. Stalwart queued the message and delivered it to all recipients during that wait. This can cause duplicate sends when users retry.
Submission awaits a local queue refresh, but the queue manager is not started when outboundMta is disabled. The same code path remains in 0.16.23. Skipping the local refresh on such nodes while retaining the cluster broadcast appears to address the issue.
- Run four Stalwart processes against the same FoundationDB data store and Redis
coordinator:
- Three frontend replicas accepting SMTP and IMAP traffic, with outboundMta disabled.
- One separate outbound worker with outboundMta enabled.
- Send sustained traffic through the same submission frontend (port 465, TLS)
until its local queue notification channel fills, then submit another message. (The 1,024-event threshold is inferred from the code, not measured directly.)
Built from source
FoundationDB
