The server complains about not finding the spam classifier model on every startup.
I have not changed any of the classifier settings, and the model is set to the default of FTRL-Proximal + Feature Hashing.
Restart the server and check the log output.
2026-05-25T00:15:33Z INFO Spam classifier model not found (spam.model-not-found)
2026-05-25T01:21:54Z INFO Starting Stalwart Server (server.startup) hostname = "mx1.example.ca", version = "0.16.6"
2026-05-25T01:21:54Z INFO Spam classifier model not found (spam.model-not-found)
2026-05-25T02:47:14Z INFO Starting Stalwart Server (server.startup) hostname = "mx1.example.ca", version = "0.16.6"
2026-05-25T02:47:14Z INFO Spam classifier model not found (spam.model-not-found)
2026-05-26T03:00:56Z INFO Starting Stalwart Server (server.startup) hostname = "mx1.example.ca", version = "0.16.6"
2026-05-26T03:00:56Z INFO Spam classifier model not found (spam.model-not-found)
2026-05-26T05:29:21Z INFO Starting Stalwart Server (server.startup) hostname = "mx1.example.ca", version = "0.16.6"
2026-05-26T05:29:21Z INFO Spam classifier model not found (spam.model-not-found)
2026-05-26T05:48:19Z INFO Starting Stalwart Server (server.startup) hostname = "mx1.example.ca", version = "0.16.6"
2026-05-26T05:48:19Z INFO Spam classifier model not found (spam.model-not-found)
2026-05-26T06:03:07Z INFO Starting Stalwart Server (server.startup) hostname = "mx1.example.ca", version = "0.16.6"
2026-05-26T06:03:07Z INFO Spam classifier model not found (spam.model-not-found)
2026-05-26T06:17:22Z INFO Starting Stalwart Server (server.startup) hostname = "mx1.example.ca", version = "0.16.6"
2026-05-26T06:17:22Z INFO Spam classifier model not found (spam.model-not-found)
2026-05-26T06:20:19Z INFO Starting Stalwart Server (server.startup) hostname = "mx1.example.ca", version = "0.16.6"
2026-05-26T06:20:19Z INFO Spam classifier model not found (spam.model-not-found)
2026-05-26T06:40:01Z INFO Starting Stalwart Server (server.startup) hostname = "mx1.example.ca", version = "0.16.6"
2026-05-26T06:40:01Z INFO Spam classifier model not found (spam.model-not-found)
2026-05-26T06:47:07Z INFO Starting Stalwart Server (server.startup) hostname = "mx1.example.ca", version = "0.16.6"
2026-05-26T06:47:07Z INFO Spam classifier model not found (spam.model-not-found)
2026-05-26T06:48:05Z INFO Starting Stalwart Server (server.startup) hostname = "mx1.example.ca", version = "0.16.6"
2026-05-26T06:48:05Z INFO Spam classifier model not found (spam.model-not-found)
2026-05-26T07:09:28Z INFO Starting Stalwart Server (server.startup) hostname = "mx1.example.ca", version = "0.16.6"
2026-05-26T07:09:28Z INFO Spam classifier model not found (spam.model-not-found)
2026-05-26T07:55:31Z INFO Starting Stalwart Server (server.startup) hostname = "mx1.example.ca", version = "0.16.6"
2026-05-26T07:55:31Z INFO Spam classifier model not found (spam.model-not-found)
2026-05-26T07:59:27Z INFO Starting Stalwart Server (server.startup) hostname = "mx1.example.ca", version = "0.16.6"
2026-05-26T07:59:27Z INFO Spam classifier model not found (spam.model-not-found)
2026-05-27T00:19:09Z INFO Starting Stalwart Server (server.startup) hostname = "mx1.example.ca", version = "0.16.6"
2026-05-27T00:19:09Z INFO Spam classifier model not found (spam.model-not-found)
2026-05-27T00:35:50Z INFO Starting Stalwart Server (server.startup) hostname = "mx1.example.ca", version = "0.16.6"
2026-05-27T00:35:50Z INFO Spam classifier model not found (spam.model-not-found)
2026-05-27T01:03:21Z INFO Starting Stalwart Server (server.startup) hostname = "mx1.example.ca", version = "0.16.6"
2026-05-27T01:03:21Z INFO Spam classifier model not found (spam.model-not-found)
2026-05-27T03:06:57Z INFO Starting Stalwart Server (server.startup) hostname = "mx1.example.ca", version = "0.16.6"
2026-05-27T03:06:57Z INFO Spam classifier model not found (spam.model-not-found)
2026-05-27T04:00:54Z INFO Starting Stalwart Server (server.startup) hostname = "mx1.example.ca", version = "0.16.6"
2026-05-27T04:00:54Z INFO Spam classifier model not found (spam.model-not-found)
2026-05-27T06:11:14Z INFO Starting Stalwart Server (server.startup) hostname = "mx1.example.ca", version = "0.16.6"
2026-05-27T06:11:14Z INFO Spam classifier model not found (spam.model-not-found)
2026-05-28T21:03:31Z INFO Starting Stalwart Server (server.startup) hostname = "mx1.example.ca", version = "0.16.6"
2026-05-28T21:03:32Z INFO Spam classifier model not found (spam.model-not-found)
2026-05-29T19:36:52Z INFO Starting Stalwart Server (server.startup) hostname = "mx1.example.ca", version = "0.16.7"
2026-05-29T19:36:52Z INFO Spam classifier model not found (spam.model-not-found)
2026-05-31T00:13:29Z INFO Starting Stalwart Server (server.startup) hostname = "mx1.example.ca", version = "0.16.7"
2026-05-31T00:13:29Z INFO Spam classifier model not found (spam.model-not-found)
2026-06-01T18:17:10Z INFO Starting Stalwart Server (server.startup) hostname = "mx1.example.ca", version = "0.16.7"
2026-06-01T18:17:10Z INFO Spam classifier model not found (spam.model-not-found)
2026-06-09T12:05:55Z INFO Starting Stalwart Server (server.startup) hostname = "mx1.example.ca", version = "0.16.8"
2026-06-09T12:05:55Z INFO Spam classifier model not found (spam.model-not-found)
2026-06-16T17:59:46Z INFO Starting Stalwart Server (server.startup) hostname = "mx1.example.ca", version = "0.16.9"
2026-06-16T17:59:46Z INFO Spam classifier model not found (spam.model-not-found)
2026-06-23T01:28:41Z INFO Starting Stalwart Server (server.startup) hostname = "mx1.example.ca", version = "0.16.9"
2026-06-23T01:28:41Z INFO Spam classifier model not found (spam.model-not-found)
2026-06-23T01:28:45Z INFO Starting Stalwart Server (server.startup) hostname = "mx1.example.ca", version = "0.16.9"
2026-06-23T01:28:45Z INFO Spam classifier model not found (spam.model-not-found)
2026-06-23T01:35:11Z INFO Starting Stalwart Server (server.startup) hostname = "mx1.example.ca", version = "0.16.10"
2026-06-23T01:35:11Z INFO Spam classifier model not found (spam.model-not-found)
2026-06-23T01:35:35Z INFO Starting Stalwart Server (server.startup) hostname = "mx1.example.ca", version = "0.16.10"
2026-06-23T01:35:35Z INFO Spam classifier model not found (spam.model-not-found)
2026-06-27T23:22:52Z INFO Starting Stalwart Server (server.startup) hostname = "mx1.example.ca", version = "0.16.11"
2026-06-27T23:22:52Z INFO Spam classifier model not found (spam.model-not-found)
2026-07-02T00:26:16Z INFO Starting Stalwart Server (server.startup) hostname = "mx1.example.ca", version = "0.16.11"
2026-07-02T00:26:16Z INFO Spam classifier model not found (spam.model-not-found)
2026-07-03T22:48:09Z INFO Starting Stalwart Server (server.startup) hostname = "mx1.example.ca", version = "0.16.11"
2026-07-03T22:48:09Z INFO Spam classifier model not found (spam.model-not-found)
2026-07-13T05:14:18Z INFO Starting Stalwart Server (server.startup) hostname = "mx1.example.ca", version = "0.16.11"
2026-07-13T05:14:18Z INFO Spam classifier model not found (spam.model-not-found)
2026-07-13T05:15:57Z INFO Starting Stalwart Server (server.startup) hostname = "mx1.example.ca", version = "0.16.13"
2026-07-13T05:15:57Z INFO Spam classifier model not found (spam.model-not-found)
2026-07-20T13:59:47Z INFO Starting Stalwart Server (server.startup) hostname = "mx1.example.ca", version = "0.16.14"
2026-07-20T13:59:47Z INFO Spam classifier model not found (spam.model-not-found)
2026-08-01T20:02:00Z INFO Starting Stalwart Server (server.startup) hostname = "mx1.example.ca", version = "0.16.15"
2026-08-01T20:02:00Z INFO Spam classifier model not found (spam.model-not-found)
2026-08-02T21:45:59Z INFO Starting Stalwart Server (server.startup) hostname = "mx1.example.ca", version = "0.16.16"
2026-08-02T21:45:59Z INFO Spam classifier model not found (spam.model-not-found)
2026-08-10T21:38:32Z INFO Starting Stalwart Server (server.startup) hostname = "mx1.example.ca", version = "0.16.17"
2026-08-10T21:38:32Z INFO Spam classifier model not found (spam.model-not-found)
2026-08-18T07:36:02Z INFO Starting Stalwart Server (server.startup) hostname = "mx1.example.ca", version = "0.16.18"
2026-08-18T07:36:02Z INFO Spam classifier model not found (spam.model-not-found)
From versions v0.16.6 through v0.16.18 inclusive.
