Split encoded-words not recognised
Multiple encoded-words inside a quoted filename= / name= parameter are decoded one at a time and the whitespace between them is kept. Gmail and Outlook send long non-ASCII filenames this way, even though RFC 2047 section 5 doesn’t allow encoded-words in quoted strings. A correctly split name gets an extra space. A name split mid-character gets U+FFFD.
The charset labels cp949, x-windows-949 and UHC are not recognised. The text is then decoded with the wrong charset and comes out entirely garbled. ks_c_5601-1987, windows-949 and euc-kr work, including CP949-only characters such as 똠, so the decoder exists and only these names are missing.
  1. filename=“=?UTF-8?B?7KCV6riw7KCQ6rKA?= =?UTF-8?B?7JWI64K0LnBkZg==?=” gives 정기점검안내.pdf. The rule used for unstructured text should apply here too: whitespace between adjacent encoded-words is ignored (RFC 2047 section 6.2), and adjacent words in the same charset are joined before decoding.
  2. cp949, x-windows-949 and UHC are treated as aliases of windows-949, as Python (cp949, uhc) and Java (x-windows-949) already do.
  1. attachments.name is “정기점검 안내.pdf” (extra space). If the sender splits a character across two words, the name is “정기� ��검� �내.pd f”.
  2. Subject: =?cp949?B?waSx4sGhsMsgvsizuyCMYw==?= gives a garbled subject (“����ý��� …”) instead of “정기점검 안내 똠”. A body with Content-Type: text/plain; charset=cp949 is garbled the same way.
  1. Import this message with Email/import, or deliver it over SMTP:
To: [email protected]
Date: Thu, 1 Oct 2026 10:00:00 +0000
MIME-Version: 1.0
Content-Type: multipart/mixed; boundary=“b”
–b
Content-Type: text/plain; charset=utf-8
hi
–b
Content-Type: application/pdf
Content-Disposition: attachment; filename=“=?UTF-8?B?7KCV6riw7KCQ6rKA?= =?UTF-8?B?7JWI64K0LnBkZg==?=”
Content-Transfer-Encoding: base64
JVBERi0xLjQK
–b–
  1. Run Email/get with properties [“subject”, “attachments”].
  2. subject is garbled and attachments[0].name is “정기점검 안내.pdf”.
Built from source
This looks like a genuine parsing issue rather than a documentation question, so I’ll flag it for human triage rather than guess at a fix.
Both behaviors you describe (not joining adjacent same-charset encoded-words across whitespace in quoted parameters, and missing cp949/x-windows-949/UHC as windows-949 aliases) live in the MIME header/charset decoding logic that Stalwart’s parser uses internally, not in anything exposed or documented at the configuration level. I was not able to find documentation or exposed configuration that would let this be worked around (there’s no charset-alias or encoded-word setting), which matches your finding that this is a decoder bug rather than a config gap.
A human maintainer will need to confirm and address this in the underlying parsing code, since it’s not something I can verify or fix by searching documentation.
The first issue is because, as you suspected, the header violates RFC 2047, twice actually:
“An ‘encoded-word’ MUST NOT appear within a ‘quoted-string’.”
“An ‘encoded-word’ MUST NOT be used in parameter of a MIME Content-Type or Content-Disposition field, or in any structured field body except within a ‘comment’ or ‘phrase’.”
The second issue was due to a missing charset mapping in mail-parser which has been added just now.
