Stacking Licenses
In the pricing FAQ on the Stalwart website, it states:
“What happens if my mailbox count exceeds my plan mid-cycle?
Existing mailboxes keep working without restriction; the server simply stops creating new mailboxes once your licensed count is reached. To unblock new mailboxes, buy additional licenses at license.stalw.art and apply them to the running server: there is no downtime and the system generates a prorated invoice for the remaining period.”
This raises a question for me: Is it possible to add additional mailbox licenses to an existing subscription without replacing the current license?
For example, let’s say I have a 12-month license covering 150 mailboxes, but at some point I need an additional 50 mailboxes.
From what I can see, there doesn’t seem to be an option to simply purchase 50 additional mailboxes and add them to my existing license. Instead, it looks like I would need to purchase a new license covering 200 mailboxes.
Am I misunderstanding how the licensing works, or is there a way to extend the existing license without having to replace it?
Ideally, I’d like to avoid a situation where I need more mailboxes but have to replace an already active and paid-for license just to increase the mailbox limit.
Yes, you can add mailboxes mid-cycle without replacing your existing license as a separate product purchase. Per the pricing FAQ, you simply buy additional mailbox licenses at license.stalw.art at any time during your billing period and apply the new key to the running server. This takes effect without a restart or downtime, and the system charges only a prorated invoice for the remaining period of your current cycle, so you don’t need to cancel or replace your existing 150-mailbox license to bump it up to 200.
Reference: Pricing FAQ (“Can I purchase additional mailboxes mid-cycle?”)
In the Settings on my Stalwart Server i do not see the Option to add a second License.
You don’t need a second license. Raise the mailbox count on your existing subscription at license.stalw.art: you’re invoiced a prorated amount for the rest of the term and get a new key covering 200 mailboxes, which replaces the current one in the Enterprise settings. Nothing you’ve already paid for is lost. The FAQ wording makes it sound like you’d add separate keys side by side, so we’ll change it.
