I decommissioned the old single node Stalwart mail server and deployed a five nodes HA cluster Stalwart with foundationdb. Added all five nodes and configured the cluster cordinatior using Zenoh peer-to-peer with the following configuration string successfully. “{
“@type”: “Zenoh”,
“config”: “{\n mode: peer,\n scouting: {\n multicast: {\n enabled: true,\n address: "224.0.0.224:7446",\n interface: "auto",\n autoconnect: { router: , peer: ["router", "peer"] },\n listen: true,\n },\n },\n}”
Copied as it is from the documentation. I also enable {
“@type”: “Zenoh”,
I also, edited the stalwart.env and enabled "STALWART_ROLE=primary on one of the node as a test.
However, I am experiencing the following three issues:-
- The nodes kept going in “Stale” state. Restarting the Stalwart put it back to active and few minutes later it goes into the stale state.
- I have an 150 Enterprise Licenses and active. However, addting the prevous unused license fails to retain in Stalwart and activate the Enterprise features though it said it is installed successfully.
3.I also am having difficulty getting SSL certificate. The ACME provider is configured to use RFC2136 TCP and TLS is set to use DNS-01-Persistent
Any help or guide is highly appreciated. Thank you.
Stalwart should be able to retain the Enterprise license and activate the features. Second, the nodes should not be able to go into stale state unless I forgot to do something else that I am not aware of. Third, Stalwart should be able to obtain SSL certs without any issue using RFC2136 protocol. I have seen issuses with Certbot and RFC2136 protocol to obtain SSL certificate in the past with Nginx Proxy Manager. However, I am not sure what Stalwart uses to request certs.
FoundationDB
FoundationDB
