Stalwart-migrate: run --final fails verification on vCard N/ADR; 1.0.4 (the fix) was never published
Migrating a single-node 0.16.27 Podman deployment (RocksDB, 3 accounts, ~70 emails, 140 contacts) to 1.0.1 with stalwartlabs/stalwart-migrate. The final run fails verification on contact cards in every available version of the tool.
The 1.0.4 changelog lists a matching fix (“Verify no longer reports contact cards whose vCard 3.0 N or ADR has extra trailing components as mismatched”), but 1.0.4 was never released: the tag v1.0.4 exists, yet the Release workflow on 2026-10-29 failed in every Build job (CI Clippy exited with code 101). Docker Hub and GHCR only have up to 1.0.3.
So a 0.16 → 1.0 migration with contacts cannot be finalised right now without --allow-errors. We rolled back to 0.16.27 (the source store is untouched) and are waiting.
Could you:
  1. publish 1.0.4 (images), and
  2. confirm that the fix also covers vCard 4.0 cards (ours are 4.0, the changelog says 3.0) and the ADR case where the extra components hold data? For ADR it should be a real difference, not a false positive.
run --final verifies the migrated contact cards as equal (they only differ in empty trailing N components) and marks the migration done.
run --final fails verification with 140 mismatches, all “contactCard … differs in the target: vcard” in one account, and the final run is not marked done. Same result with stalwart-migrate 1.0.0 and 1.0.3, on a fresh state directory and a fresh target store.
The stored cards are vCard 4.0: all 140 have an N with 7 components (components 6–7 empty); 4 also have an ADR with 18 components, with data beyond component 7.
  1. Stalwart 0.16.27 (Podman, RocksDB) with an address book of vCard 4.0 contacts whose N has 7 components.
  2. stalwart-migrate:1.0.3 prepare --non-interactive (all recommended answers), then run: 0 errors.
  3. Stop 0.16, then: run --final --yes --source /etc/stalwart/config.json --target /etc/stalwart-v1/config.json --state /var/lib/stalwart-migrate --target-path-map /var/lib/stalwart=/var/lib/stalwart-v1
  4. Verification fails with the contactCard mismatches.
run 1: ok ({"accounts_failed":0,"accounts_full":3,"emails_written":69,"errors":0,"objects_written":250,"registry_written":2832})
verify: 3 accounts checked, 140 mismatches, 140 not explained by earlier reports (failed)
finalize completed but verification failed: the final run is not marked done. Fix the reported mismatches (stalwart-migrate report --severity verify) and run --final again.
$ stalwart-migrate report --severity verify
run  severity  category  account  object       id  message
3    verify    mismatch  3        contactCard  9   differs in the target: vcard
3    verify    mismatch  3        contactCard  8   differs in the target: vcard
... (140 rows, all contactCard / vcard, account 3)
v1.x
Tool images tried: stalwartlabs/stalwart-migrate 1.0.0 and 1.0.3 (1.0.3 = latest); target server image stalwartlabs/stalwart:v1.0.1. Podman with Quadlet, Caddy as reverse proxy (http_forwarded answered as xForwardedFor, 1 hop). The data set is small (about 9 MB), so we can re-run the migration quickly once 1.0.4 is available.
Nothing I found in the docs or the server source covers this, so I can’t answer your questions. That includes whether 1.0.4 will be published, whether its fix covers vCard 4.0 N values, and whether it treats a populated ADR as a real difference. The 1.0.4 changelog entry and the failed Release workflow you describe are not in the repos I can search, and I haven’t confirmed them.
The docs do say two things that bear on your case:
  • verify and run --final compare contacts after parsing, so equivalent vCard texts should count as equal.
  • Verify rows that no earlier report explains keep run --final from finalising. --allow-errors does not accept them, as the verification docs state. Your 140 mismatches are verify rows, so --allow-errors would not get you past them, whatever the 1.0.4 issue turns out to be.
Rolling back to 0.16.27 while you wait was the safe choice, since the source store is untouched.
1.0.4 came out 2 minutes before your post.
on 1.0.4 migration worked. thx!
