I am building stalwart-migrate (oss variant with excludes enterprise and foundation build features) from source, and I have noticed tenant_domain_with_a_global_acme_provider_is_migrated test never succeeds on aarch64-darwin. It’s been recurrent since it was introduced in v1.0.1. The same test on x86_64-linux passes. Additionally, the default variant has no build or e2e test integration failures.
failures:
---- tenant_domain_with_a_global_acme_provider_is_migrated stdout ----
thread 'tenant_domain_with_a_global_acme_provider_is_migrated' (32543431) panicked at crates/migrate/tests/e2e.rs:3140:5:
[RegistryRecord { key: RegistryKey { object: "x:Domain", id: Id(5) }, json: Object {"aliases": Object {}, "allowRelaying": Bool(false), "catchAllAddress": Null, "certificateManagement": Object {"@type": String("Automatic"), "acmeProviderId": String("iq23htewaaqa"), "subjectAlternativeNames": Object {}}, "createdAt": String("2026-10-27T23:41:50Z"), "description": Null, "dkimManagement": Object {"@type": String("Automatic"), "algorithms": Object {"Dkim1Ed25519Sha256": Bool(true), "Dkim1RsaSha256": Bool(true)}, "deleteAfter": Number(2592000000), "retireAfter": Number(604800000), "rotateAfter": Number(7776000000), "selectorTemplate": String("v{version}-{algorithm}-{date-%Y%m%d}")}, "dnsManagement": Object {"@type": String("Manual")}, "enable": Bool(true), "name": String("example.org"), "reportAddressUri": String("mailto:postmaster"), "subAddressing": Object {"@type": String("Enabled")}} }]
note: run with `RUST_BACKTRACE=1` environment variable to display a backtrace
Help explain the purpose of this test and help me determine if this is a false positive.
edit: update target platform that it was failing on from aarch64-linux to aarch64-darwin
