Stalwart/webui 2.0.3 requires idp reconfiguration despite it being a patch release
Hi community,
I just wanted to make users aware that webui 2.0.3 could require reconfiguration of an external IDP.
since webui 2.0.3 the authorization request includes a resource parameter.
So if anyone uses an IDP checking the resource it could mean you need to reconfigure your IDP so that you can still login.
For example in Pocket-ID you need to add an API with https://yourmailserver.example.net for the resource uri and no specific permissions. You then have to allow access to that API in the OIDC client config.
Else it could be that you will receive the error: “The request is missing a required parameter, includes an invalid parameter value, includes a parameter more than once, or is otherwise malformed. The ‘resource’ or ‘scope’ parameter is invalid.” which means that the idp sent the RFC 8707 error ‘invalid_target’ as a response to the authorization request.
BR,
Fabian
